Primus 50 & 53 steel 'Discus' stoves
Discussion in 'Primus No:50' started by brassnipplekey, May 16, 2009.
  1. brassnipplekey
    A recent posting of a Steel bodied Primus 152 prompted me to dig out this pair.
    The 50 is the roarer & undated (the dull body).
    The 53 is silent & dated AU = 1955 (shiny like new ).
    Both have the same taper thread riser ..Like the 210 stove.
    1242484211-PICT3733.JPG 1242484232-PICT3736.JPG 1242484250-PICT3737.JPG 1242484275-PICT3738.JPG 1242484303-PICT3740.JPG 1242484323-PICT3741.JPG 1242484342-PICT3742.JPG 1242484356-PICT3743.JPG 1242484374-PICT3744.JPG 1242484422-PICT3745.JPG 1242484442-PICT3746.JPG 1242484458-PICT3747.JPG 1242484483-PICT3748.JPG 1242484508-PICT3750.JPG 1242484531-PICT3752.JPG 1242484545-PICT3753.JPG 1242484574-PICT3755.JPG 1242484649-PICT3756.JPG 1242484676-PICT3758.JPG 1242484760-PICT3761.JPG
    Noting :- Different fill caps/pressure release , Different diameter pump tubes ,53 being larger.
    The riser socket in both stoves is brass .. surrounded by plated brass collar on which the model number is marked .. The 50 has had this collar soldered (rough) .. on the 53 you can easily see that this is a separate, but attached, piece.
    Interesting that on these 'budget' stoves the pump rod is brass. The feet are steel. The date marking is on the top of the tank.
    Nick
  2. Dutchmike
    Netherlands
    Great pics, Nick. Thank you! regards, Mike
