Primus 533/704
Discussion in 'Primus No:704' started by Tracer, Feb 17, 2012.
  1. Tracer
    Tracer Subscriber
    This one took me a 4 hour drive, but it was all worth it.
    The previous owner said it was used for melting lead.
    I even got the witches cauldron and the ladle. It's cast iron and looks great, no cracks or missing parts, stamped Primus 533T Made in Sweden.
    The stove is a Primus 704 (and it's big).
    The bottom of the stove is marked AO4 with the 4 underneath the AO.
    It was a good day and well worth the drive.
    Thanks for looking!
  2. RonPH
    That's one of the big ones Primus made. Very nice condition and well worth the drive :thumbup:
    Flameshotes please :mrgreen:
    Ron
  3. mr optimus
    mr optimus Subscriber
    Hi Tracer yes the previous owner is right it is a plumbers furnace used for melting lead for joining lead pipes,
    A very nice example and all complete even with the pouring ladle, it will be nice to see it fired up
  4. Shed-man
    Shed-man R.I.P.
    Lovely, great big lead melter. Nice! If you live anywhere near the coast or rivers, get some casts for making fishing weights, some scrap lead, and put it back to work, maybe? Great stove. Look forward to some pics of it in action. Steve.
  5. nmp
  6. Wim
    Wim Subscriber
    Lovely! So, that's why you've been so quiet lately! :lol: To bussy with searching stoves... ;)
    Best regards,
    Wim
  7. Doug L
    Doug L Subscriber
    USA
    Looks real nice.
    I need to travel europe when I retire and bring a empty suitcase.
  8. Tracer
    Tracer Subscriber
    It surprised me that I couldn't find anything about the 533T or 704 stove in the catalogues.
    Even Google didn't bring up some information.
    If I find some time this afternoon, I check the pumpleather and the pip.
    @Wim: Bachman Turner Overdrive. :oops:
  9. gunsoo
    Hey Tracer.
    you right i think worth the drive too.
    Perfect melting set!!
    just like watch catalogue :shock:
    thanks sharing.
    Gunsoo
  10. Rangie
    Rangie Subscriber
    Hello @Tracer, would you be so kind as to measure your flame ring/tube for me please?
    I have one without a tube and plan to machine one up.
    OD & ID at top and bottom (sometimes they are tapered), and length if you would be so kind. Its useful reference material as well :content:
    Alec.
  11. Afterburner
    Primus 1934 catalog says that hole of flame tube is 74mm (must be ID) and whole height of the stove is 360mm. Length of the flame tube can be measured by using that 'whole height' when stove is set on floor or table. Length of flame tube is not so critical... bit (~1 cm) over burner top should be ok.
    ID can be also measured from burner's max. diameter = flame tube goes into it's position freely. OD is that it fits inside of flame ring support ring.
  12. Rangie
    Rangie Subscriber
    The max OD of my tube would be 55mm or just under. I'd rather get a measurement off of a 704 to be certain I have the correct burner.
    Which catalogue were you looking at?
    Alec.
  13. Afterburner
  14. Tracer
    Tracer Subscriber
  15. Tracer
    Tracer Subscriber
    Just had a check, I do doubt this is the orginal as it has no markings, but it should work.
    Lenght = 75 mm
    Inside diameter = 69 mm
    Outside diameter = 78 mm
