primus 535 spirit tube & wick clone
Discussion in 'Stove Forum' started by Geoff Chirnside, Mar 5, 2021.
  1. Geoff Chirnside
    Geoff Chirnside Subscriber
    New Zealand
    I have two 535's both came with only one spirit tube each and one wick between them,
    I sacrificed one spirit tube to get a pattern
    I rolled one of them around a brass rod
    but it had to be annealed to get the final shape right
    I cloned the clip as well, I had some stainless steel welding rod that has plenty of spring to it,
    the clones are on the right.
    Here is the clone fitted
    And the original back on the burner that it came on
    I needed a wick and luckily after spending hours on the internet trying to find a solution I discovered
    that I aready had exactly what I needed.
    I had replaced the seal around the door glass of our inbuilt fire and the old seal was sitting in a box
    in my garage, pays not to throw things out. It is fibreglass and I managed to cut off a strip the exact
    width that I needed, a brass backing strip and we are in business.
    Fitted with a couple of clasps
    The original wick had the clip in the top missing so a bit of cutting and bending of brass sheet
    and it is ready live on.
    reassembled and looking down on the clone where it will now reside
    Got fire
    Both burners are preheating but I only caught the flames from one in my shot.
    A problem that I predicted but is not major is the wick burns with a flame along its entire
    length, this promotes under burn until it is completely burned out.
    The tubes and wick would work better if the slit in the tube was completely closed.
    Perhaps a modification of the original design might be called for.
    Any thoughts anyone?
