Primus 702 London 710 Furnace
Discussion in 'Primus No:702' started by Stu B, May 5, 2021.
  1. Stu B United Kingdom
    Cumbria
    Latest project arrived yesterday looking to get it up and running to use as a lead smelter
    Plumbers Furnace London 710 with it’s Primus 702 burner
    It’s in a bit of a sorry state very rusty but still solid all considering the age of it
    fortunately though the burner is holding pressure so a good strip down clean fingers crossed will see it serviceable and running as it was intended
    will update as things progress any advice would be greatly received
    5EE3909E-20B7-49EB-80A5-6BA543A547D5.jpeg 77499546-DEDF-4ED9-B76C-0C10DBEE4221.jpeg
    After a brief inspection the three legs on the 710 furnace stand are out of alignment slightly as the burner isn’t sitting central looks like it’s took a knock
    So I’ve decided on a full strip down of this is probably the only way to get everything lined up correctly
  2. Stu B United Kingdom
    Cumbria
    Forgot to add advice on dating this setup would be welcome :content:
    burner tube is missing 55mm outside diameter
    I can easily source some steel tubing for now until I can eventually find some cast pipe
    just need to know it’s overall length ?
  3. ROBBO55
  4. Stu B United Kingdom
    Cumbria
    Appreciated any advice is welcome
  5. Stu B United Kingdom
    Cumbria
    Progress so far after a day off work
    B12F8883-E88D-4BE4-BB57-A48376EA08AD.jpeg B1BE7917-3D98-4D8F-82FF-7D00D870860B.jpeg D69DB053-F03F-4096-B52C-A844E4E50755.jpeg B47C7EF9-A356-48E1-B5DA-259C877CE4D9.jpeg
  6. Brenneman
    Brenneman Subscriber
  7. kerophile
    What a difference a day makes....
  8. Andrew
    Port Elizabeth South Africa
    1949 date Primus 702 by Presscall in the reference gallery will give you the tube measurements (second last post).
  9. kerophile
  10. Stu B United Kingdom
    Cumbria
    Thanks appreciated will try and source some tubing
  11. Stu B United Kingdom
    Cumbria
    Fired up the Primus 702 burner tonight for around half an hour holding good pressure with no signs of any leaks or weeping fuel
    9D1C252A-1E8D-4B04-BE12-9855B95D68C5.jpeg 715E053B-6CE0-4B9F-A1B8-EFC8A696315A.jpeg FE53BFB5-698B-42A1-9BD6-B1041B403763.jpeg
  12. ROBBO55
    It's cleaned up nicely and what a beautiful flame! Congratulations :thumbup::thumbup:
  13. Tony Press
    Excellent!
  14. Jaime Massang
    Jaime Massang Australia Subscriber
    Jules Verne, H.G. Wells, Goddard and all you rocketeering steam punks out there, eat your heart out!
  15. kerophile
    Outstanding flame shots and an impressive restoration! I
    look forward to seeing how the outfit handles lead melting.
