Primus 96, large yellow flame after double priming
Discussion in 'Fettling Forum' started by Sternenlicht, Jul 24, 2021.
  1. Sternenlicht
    Sternenlicht Subscriber
    Hürtgenwald
    Dear all,
    after some time of absence I am back with a question to the only Primus 96 I have:
    It needs at least two times, sometimes more than two, of priming with ethanol to burn with a nice blue flame. As I got that stove the jet hole was little too large, the flame was a little yellow, but only one time priming was needed. I peened the jet hole down to ~0.2mm and changed the inner mesh. From that on, it needs much more time for priming. In between I put in the original mesh, but it did not change anymore.
    What did I wrong?
    Ciao, Bastian
  2. hikerduane
    New crack? I've never had my peened lipsticks come close to what you show, even before I peened them tighter. Look closely at the tip maybe. I had to "push" out a crushed tip one time and used too large a diameter bolt to do it, it burned real yellow like you show, so had to silver solder the damage, I am unable to silbraze.
  3. IvanN
    N.E. Oregon
    If the only changes were peening the jet and the mesh, I suspect the mesh. I’m not a regular 96 user, certainly not an expert, but the only time I’ve had a flame like that it was a mesh issue. I had to readjust it several times to get the fuel to vaporize properly, once I did it was back to normal.
    Ivan
  4. kerophile
  5. hikerduane
    Most cases I'm sure. I've even fired up one of my 96's w/o putting the mesh back in after cleaning, ran fine, did not run too long, so don't know if it would have kept going. I've never had issues with depth the mesh was placed in, although I try to poke it all the way up. I'd think the flame would turn yellowish if poor thermal feedback thru all the parts after initial preheat.
  6. Twoberth
    England
    That flame looks like a large amount of kerosene is escaping, far more than I would expect to escape from a 0.2mm hole, even without the mesh.
    Sometimes when peening the outside around the jet hole (with a mandrel inside the lipstick), the lipstick end can crack. Check to make sure the tip area around the jet hole is still sound.
  7. Sternenlicht
    Hürtgenwald
    Thank you all for the reply and the interesting links. I checked the lipstick, no cracks! I also tried some different mesh rolls, bug no success. But I will keep on trying!
    Ciao, Bastian
  8. presscall
    Peening can certainly result in cracks, maybe one not visible.
    Granted, THIS example of a crack produced by peening was visible!
  9. hikerduane
    I think I would take the stove outside and pump it up to see where the excess fuel is coming from. Should only have the single stream out of the orifice. Correct fuel?
  10. Sternenlicht
    Hürtgenwald
    I'm using the same fuel as in my other kerosene stoves, I can exclude that.
    Thanks for the good photograph! Mine are much worse, but I hope you can see the quality of the surface:
    Absolutely no cracks! I peened the hole and drilled it with a 0.2mm drill. That was closest to 0.23mm I could reach.
    But I will pump it tomorow!
    Ciao, Bastian
  11. Sternenlicht
    Hürtgenwald
    So, my stove is working again. I checked the stream out of the orifice, looks good. Then I put in the fine brass mesh which was in before and primed one time, the stove runs great!
    The only thing I changed was to loose the mesh roll a bit, nothing more... so I think it really was a matter of the mesh.
    Thanks fir the great help!
    Ciao, Bastian
  12. kerophile
    Hi @Sternenlicht . I am pleased that you have your Primus No.96 operating well again.
  13. IvanN
    N.E. Oregon
    Glad you got it, and thanks for posting the result. It’s useful to learn what to he final fix was.
    Ivan
  14. Sternenlicht
    Hürtgenwald
  15. Sternenlicht
    Hürtgenwald
    Hey again,
    I thought everything is fine, but today I tried to fire it at little wind (with good wind shield) and I had the same problems again. Directly after, I fired my Ahno lipstick burner, after a short priming it burned perfectly.
    What are the differences between both stoves?
    The Ahno is larger, so I would assume it needs longer priming. The inner mesh is similar. But maybe its the fact, that the burner bell of the Ahno sits quite narrow on the lipstick. The bell of the 96 sits very wobbly on the lipstick. So maybe the thermal conductivity during priming between bell and lipstick is not that good?!
    Ciao, Bastian
  16. kerophile
  17. hikerduane
    You got it, I've had to shim some of my bells, I even have a bell that the PO cut the bell and squeezed it tighter. Issues are manifested when outside or in a breeze, even with wind protection.
  18. presscall
    What Duane said.
    A shim works.
    F0624C37-101C-4CD4-8D7E-CBC5167C1C95.jpeg DFDF0025-D5A9-4559-BED1-6C6FFAE5B27C.jpeg
    A more elegant solution is to make a saw cut in the mounting boss, squeeze it to match the taper of the vapouriser …
    C007AE39-173C-4EBE-8BDF-0F4E5CC409F8.jpeg 20D39516-818B-49E8-BCAB-EA2A02AF4585.jpeg
    … and silbraze the join.
    03C9367B-7A8C-449E-8D65-989367700451.jpeg 23300119-F9BA-47A3-8233-F896A59A1F13.jpeg
  19. Sternenlicht
    Hürtgenwald
    @kerophile @hikerduane @presscall
    Thanks again for your reply, sometimes it needs some time to reach the aim. I will try the shim, but I think cut and silbraze is the proper way...
    Ciao, Bastian
  20. Sternenlicht
    Hürtgenwald
    It's done!
    I cut and silbrazed the burner bell and its running better then ever! A short prime and it is roaring like a beast!
    Thanks for all the help, the interesting links and the good advice regarding the method and the tools! @hikerduane @presscall @kerophile
    @IvanN
    Ciao, Bastian
    Cutting with a fine saw
    Pressing
    Cleaning
    Preheating with a propane torch to save MAPP gas, then silbrazing with MAPP
    Directly after
    Cleaning again
    The result
    First priming
    Nice flame, with a little large orifice it would be more powerful...
    The tool setup
