Primus No 110: heater attachment 157R
Discussion in 'Fettling Forum' started by Brenneman, May 24, 2020.
  1. Brenneman
    Brenneman Subscriber
    This 1937 nickel plated Primus No110 has been gathering dust for a while.
    Although in good condition for an 83-year old stove, it still needs to be fettled and is now next on the list to be dealt with.
    I want to add the heater attachment, but getting the original heater attachment would be like looking for a needle in a huge hay stack, so I have the ambition to recreate it myself.
    In this thread 155R - Bowl fire kit for Primus stove
    two heater attachments with different dimensions are mentioned:
    155R - reflector bowl diameter = 27.3 cm (10 3/4 inch)
    157R - reflector bowl diameter = 32.5 cm (12 inch)
    From this https://classiccampstoves.com/threads/primus-110-heater.34036/ thread I learned the 157R type reflector bowl appears the right one for the. No110.
    Apparantly 3 options for the polished bowls were available: brass, aluminum and copper.
    Both 155R and 157R appear to have a domed radiator cap with a diameter of 11 cm.
    A brass domed radiator cap can be from Parafinalia: Primus Radiant Dome
    A picture of arm/support for the domed radiator cap as found in a post in these threads
    Primus 110
    Primus No.110
    will be helpful to create my own.
    The blueprint for the reflector bowl supports is found in Doc Mark’s excellent post:
    Primus 110 Heater Bowl Supports.
    In my case the reflector bowl itself is likely going to be a Tilley/Bialladin bowl or a stainless steel mixing bowl like this one https://classiccampstoves.com/threads/bowl-transplant-for-a-bialaddin-bowlfire.14308/
    To start the hunt for a alternative for the origonal reflector bowl I am looking for 3 dimensions:
    • diameter of the bowl (is 32.5 cm/12” correct?)
    • how deep the bowl is
    • arc length of the bowl (to approximate the radius, given the diameter and depth are known).
    I would be very grateful if somebody who owns this bowl could share these dimensions!
    20200524_112512.jpg 20200523_211352.jpg 20200524_112813.jpg 20200523_211247.jpg 20200523_211325.jpg
  2. ROBBO55
    A good project :thumbup:
    I'm looking forward to seeing it completed.
  3. Tantra
    Tantra Subscriber
    China
    C035727C-0E56-4454-BC58-EE7091B8A695.jpeg 7B6EFBBD-9D3A-4FD1-9B14-61D84964830A.jpeg I have same project as well
    I found parts but need a few work
    The radars looks not enough big
  4. Tantra
    Tantra Subscriber
    China
    I should to go super market look for a pot covers
  5. Brenneman
    Tantra, good to see we have the same project running in parallel!
