Primus No. 14 - 1937 (AB 29)
Discussion in 'Primus No:14' started by Phoenix, Nov 2, 2013.
  1. Phoenix
    Hello, I'm new here & live in Belgium.
    I discovered a Primus stove on our attic.
    After some primary clean-up (some idiot painted the stove) I discovered the following :
    Primus Stove No. 14, made in Sweden with date mark AB 29 (1937 as I understood).
    The stovewas in a wooden box with several accesories : burner ring, several burner heads, a silent burner cap, jet cleaner, wrench, unopened jet cleaner in original package, wind deflector, ...
    As I am not a collector, I would like to find a new home for this stove.
    At the moment the stove is still partially painted.
    If one would be interested, you can send me a pm.
    Mind the fact though that I live in Belgium, ...
    hope you love the pictures I included & I really hope someone would like to add this stove to his or hers collection (or knows somenone who would like to).
    pictures :
    1383400844-p1100827.jpg 1383400860-p1100828.jpg 1383400890-p1100830.jpg 1383400903-p1100831.jpg
    kind regards,
    Phoenix
  2. Robtz
    Robtz Subscriber
    Wellington, N.Z.
    Hi,
    Keep it. You won't find another. Seriously.
    Or, send it far far away so you will never be tempted to come get it; send it to NZ, I'd be vey happy with it.
    Rob
    who has one already, and would be happy with two.
  3. Phoenix
    I finally got around to clean up the stove and fill it up with petrol. I got burning by pouring some spiritus in the ring under the burner and then lighting the stove. Apart from a leakage at the regulator it fired up quite nice. It's however not burning completely steady. Some pictures below.
  4. janders
    janders Subscriber
    @Phoenix I hope it is just a translation error when you say
    This stove should only use kerosene/paraffin as a fuel.
  5. Phoenix
    I actually filled it with lamp petroleum (petroleum type C) which I thought should come quite close to kerosene/paraffin.
    Am I mistaken?
    Not sure where to buy kerosene...
  6. janders
    janders Subscriber
    I am not familiar with lamp petroleum - no problem getting kerosene here. I hope someone else knows what that is and if it is suitable.
  7. janders
    janders Subscriber
    @Phoenix I did a quick search and found this. It looks like there is plenty of soot on your burner, so I'd do the test...
  8. Phoenix
    thank you for the replies. I will look further into what fuel it can use (and do the soot test).
