Finally managed to get the No7 up and running (see NRV thread) & a big thanks to Ian for sending a spare NRV. The flame does not seem right , could it be a worn jet ? I’ve used a pricker on it which helped but still not getting an even flame , any suggestions to remedy it .Flame shots below - Regards James
Yes the flame ring is missing, I have made one up from an old tin can but still the flame is not even
Or the jet is worn, or the tubes are partially blocked or polluted or a combination of both? Ciao, Bastian
First stop must be to try a new jet before delving and further. One step at a time, process of elimination. Ian
Hi Ian What other jet(s) can i use for this as this uses the 4747 one which i think is larger than the normal size jets ,also any advice as to where to get one from? Regards James
