Primus96 flame !!
Discussion in 'Stove Forum' started by qweer2006, Dec 15, 2019.
  1. qweer2006 Saudi Arabia
    asia
    Hi
    what is problem of flame ?
  2. qweer2006 Saudi Arabia
    asia
    Help me please
    help me
  3. presscall
    @qweer2006
    Prick the jet - 0.23mm size jet pricker.
    One of these.
  4. qweer2006 Saudi Arabia
    asia
    Not available in my city !
  5. presscall
    High ‘E’ string from a guitar or any fine (0.23mm or less) stiff wire.
  6. Tony Press
    @qweer2006
    A steel high “E” string of a guitar can be used to prick the jet.
    Or a thin brass wire from a cleaning brush.
    Do not force into the jet a wire that is wider than the jet.
  7. qweer2006 Saudi Arabia
    asia
    There is another problem lose pressure , kerosene come out around tank
  8. qweer2006 Saudi Arabia
    asia
    Can i use this ?
  9. Tony Press
    @qweer2006
    Before you try to fix the kerosene leak, make sure that it is not leaking from the fuel cap. The rubber washer in the fuel cap must not be hard. Check this first.
    If it is leaking from the solder on the tank you will have to re-solder it. Do not use “Auto Bond”.
  10. qweer2006 Saudi Arabia
    asia
    What do you mean auto bond ? mr tony
  11. Tony Press
    Yes. Do not use auto bond.
    It will have to be soldered.
  12. Cookie
    Florida
    @qweer2006 Auto-Bond is the stuff that you showed in your picture. If you have a blockage in the lipstick burner your leak may be an issue of over pumping to try to get the correct flame. If this was done with a "full" tank (above 80% capacity) it would easily bypass a hardened filler cap seal and run down the tube onto the tank.
    You can test the stove for leaks by removing the burner, pouring out the fuel (save it), installing the travel cap on top of the tank, and giving it a few pumps. Spray some soapy water on the travel cap and around the filler tube base. Note your bubbles if any. If this doesn't work I have dunked mine in a five gallon bucket of water and looked at my leaks after removing the pump rod. This is how I recently fettled my 96 because I also had a leak in the same area.
    On your picture with the flame shot. I noticed that your flame spreader is damaged and possibly upside down. I say that it is upside down because on mine it says "Primus" on one side. I may be completely wrong in assuming that all 96 flame spreaders are alike. I am just making an observation compared to my newer model 96.
    Suggestions: You need to check all of the areas that fuel and/or air can leak from (nrv, fuel cap seal, and at base of lipstick burner) to ensure that you do not have a pressure leak. Ensure that your burner does not have an obstruction at the jet area. Clean the wire mesh inside the burner tube with vinegar and water (greatly helped my flame). Once repaired and you have no leaks I would address the flame spreader issue.
  13. qweer2006 Saudi Arabia
    asia
    One million thank U
  14. qweer2006 Saudi Arabia
    asia
    I can't understand why kerosene not straight?
  15. qweer2006 Saudi Arabia
    asia
  16. Tony Press
    Carefully prick the jet, and then give it a careful light rub with very fine steel wool, or very very fine emery paper.
    Then prick again.
  17. qweer2006 Saudi Arabia
    asia
    Tube .. not damage ?
  18. qweer2006 Saudi Arabia
    asia
    Thank you, gentlemen, for your generosity
  19. Christer Carlsson
    It looks like you have some thing stuck in the orifice.
    Perhaps an old cleaning wire has been broken and left in the tiny hole (se blurry blow-up from your picture below).
    Try to remove that part, and I'm sure you will get a more straight jet of kerosene. A pair of needle nose pliers might get a grip on the tiny wire.
    The jet may very well have been enlarged by all this, but it's worth a try to get that piece of wire away and test again.
  20. qweer2006 Saudi Arabia
    asia
    Its work very well
    thank U all of U
