Problem extracting NRV
Discussion in 'Stove Forum' started by Migwar, Sep 15, 2021.
  1. Migwar Lebanon
    Lebanon
    Hi everyone, I have a problem extracting NRV for Radius no. 35; In fact I've prepared previously a tool that worked perfectly in opening the NRV, a very low pressure down and a light turn anticlock wise made the expected sound and the NRV started turning. I was expecting it to fall by gravity after like 7 8 turns, unfortunately that didn't happen. I kept turning and turning, try after another without having it. The NRV is released, it is loosened, turns freely, and gets out 3 to 4 mm when the stove is turned to allow gravity to work on it, but it doesn't leave the spot (the end of the tube).
    I tried gently pulling it using a 4 mm wire without success. Anyone face such a problem before?
    Many thanks and regards,
    Migwar
  2. Sparky
    Sparky Subscriber
    Houston, Tx area
    It happens. I have a 20 cm forceps for just this problem. Could be a split thread, a broken seal, who knows. I have only unsoldered one pump tube to get one out, though.
  3. kerophile
  4. snwcmpr
    I bought several lengths of alligator forseps.
  5. kerophile
  6. kerophile
    Another option is to attach a water hose to the filler hole and use water pressure to push the loose NRV out of its hole.
  7. Migwar Lebanon
    Lebanon
    Well, many thanks everyone,@Sparky @kerophile , and @snwcmpr , will get something similar to what you've advised and will reply to this thread to keep you posted. The NRV showed good amount of resistance when I've tried to pull it.
    All the best,
    Migwar
  8. Migwar Lebanon
    Lebanon
    I will try the water hose trick as a first move, many thanks @kerophile.
    Best regards, Migwar
  9. presscall
    A shallow-tapered spike (ice pick here) jammed firmly (but not destructively so!) into the NRV’s air inlet hole works for me.
  10. Migwar Lebanon
    Lebanon
    Hi again, I managed to remove that stubborn NRV. Applied this time a bit more of force after being confident from reading the above. There is a good amount of black material behind.
    The NRV itself is one piece and I donno how to service it (It is meanwhile sitting in a bath of penetrating oil). I am thinking of giving it a try, will order new one if it is going to be a long story.
    Any ideas about it please?
  11. Migwar Lebanon
    Lebanon
    Many thanks @presscall , I've managed to do pulling it using the below, not the prettiest of tools [-X, but did the job.
    Migwar
  12. hikerduane
    It unscrews. Should have a slot at one end for a screw driver. May or may not split the NRV when having to use too much force.
  13. janders
    janders Subscriber
    @Migwar
    A piece of leather and a pair of pliers to grip and hold the part that goes into the tank, the NRV tool to unscrew the top. Do NOT try a screwdriver on the end...
    Others have also used a chuck from a drill to hold the NRV.
    Good luck!
  14. kerophile
  15. Migwar Lebanon
    Lebanon
    Thank you all,
    I am going to order some NRVs, this one won't work, pip destroyed, in fact it was stuck over a rusty spring (Broken later). Pictures below.
    Your contributions are much appreciated.
    I couldn't have done any step in this, and gain such experience, without your support.
    20210915_173503.jpg 20210915_173525.jpg 20210915_174159.jpg 20210915_173457.jpg 20210915_175632.jpg 20210915_175617.jpg 20210915_175557.jpg
    Migwar
  16. janders
    janders Subscriber
    @Migwar
    Keep the old one - you know the threads are good and it fits your stove. Get this to fix it.
  17. kerophile
  18. Migwar Lebanon
    Lebanon
    Thank you very much.
  19. snwcmpr
    Yes, keep the original. They are made much better than the new ones.
