Problem with Optimus 8
Discussion in 'Stove Forum' started by Yannick Michel, Sep 8, 2021.
  1. Yannick Michel France
    France
    Hello from France
    I found an Optimus 8 with aluminum case. After having changed the wick and the gasket it works nicely. But I noticed that when it us too hot, there is a small flame escaping from the tube where there is the spindle. How to solve this problem please ?
    Thank you for your help,
    Yannick
  2. kerophile
    Hi @Yannick Michel . Nice stove!
    The control spindle operates through a “packing gland” which contains graphite. This is compressed by the hexagonal nut to prevent fuel leaking past the spindle during operation.
    The small flame that you see in operation indicates that you need to tighten the nut to seal the packing.
    You can do this while the stove is operating or after the flame is extinguished. Turn the nut clockwise until the nut is tightened but the spindle can still be turned.
    https://classiccampstoves.com/threads/fitting-replacement-parts-on-regulated-burners.8843/
  3. Yannick Michel France
    France
    Thank you Kerophile. It seems it is not possible to turn the nut clockwise more. When I removed the spindle and the nut should I see a graphite part in the tube ?
  4. Yannick Michel France
    France
    I ordered from a seller on Ebay based in England a graphite foil. How to use this foil to may be solve this problem of leaks near the spindle ?
    Thank you
    Yannick
  5. itchy
    Hi Yannick,
    There is probably a BernieDawg video on Youtube showing this process on a Svea123 or Optimus 8R, but I cannot search for one right now. Basically, you cut a small strip of the graphite tape or ribbon and wrap it around the spindle to a thickness that seems about right (it goes between the washer and the stuffing box). Then reassemble. It will be compressed and should seal. It does not take much, so do not worry about a little trial and error before you get it right.
    That stove is a nice find.
  6. Yannick Michel France
    France
    Thanks Itchy.
    i will try that. I wonder if there was at the origin graphite inside the tube of this Optimus 8 (not 8 R). After removing the spindle I can’t see something inside the tube.
  7. kerophile
  8. Yannick Michel France
    France
    Thanks Kerophile but I can’t see a graphite packing in my Optimus 8.
  9. kerophile
    Hi, It is quite likely that a previous owner removed the Pre-formed graphite packing or compressed tape.
    You do however need this graphite if you want the stove to operate as intended.
    There should be a specially shaped washer on the spindle shaft and then the pre-formed packing or rolled tape, then finally, the packing nut.
    I have given you a link earlier on fitting new parts.
    see also these instructions on using graphite tape:
    how-to-use-graphite-tape-on-optimus-111.45490
    Kerophile
  10. Yannick Michel France
    France
    Ok
    i can read a sentence in French which are speaking about amiante and not graphite. May be in mine, this part is used ?
  11. Yannick Michel France
    France
    Ok Kerophile
    Thanks a lot for these information.
    best regards
    Yannick
  12. kerophile
    Hi, Amiante or Asbestos should be avoided at all costs.
    An asbestos or asbestos/graphite composite might have been used as a packing substance at one time but I am unaware of its use on an Optimus No.8 stove.
  13. Yannick Michel France
    France
    I wonder if a graphite tape only could be used instead of the usual graphite packing ?
    and I have another question : i noticed also a flame getting out of the junction between the tank and the burner ? How to solve this other leakage ?? Sorry for my English if there is mistakes.
    Yannick
  14. kerophile
    Hi, your English is good.
    Yes, the graphite tape can be used to totally replace the packing required. It self-amalgamates as it is compressed and you can add more tape until the packing gland is sufficiently filled.
    As for the other fuel, what kind of seal do you have between fuel feed pipe and Op.8 tank base? is it a solder joint, a compression fitting or a threaded joint?
  15. kerophile
  16. Yannick Michel France
    France
    Kerophile,
    ok. I will try the graphite tape when I receive it.
    concerning the seal between the feed pipe and the tank, please look at the photo. It is a threaded joint I think.
    Yannick
  17. Yannick Michel France
    France
    Here is another photo :
  18. hikerduane
    Some thread sealant or copper based anti-seize on the threads should help. Give it a try.
  19. kerophile
    PTFE TAPE?
  20. Yannick Michel France
    France
    Don’t you think both of you than the graphite tape could also solve this leakage ?
