Problems with 8R
Discussion in 'Fettling Forum' started by William Moss, Mar 8, 2019.
  1. William Moss Canada
    Québec City, Canada
    I have an original 8R, almost brand new though bought around 1980. Can't get a blue flame on it. Any suggestions? Thanks in advance.
  2. JP2
    JP2 Subscriber
    Canada
    @William Moss
    Hi and welcome.
    Have you done any maintenance lately? If you can give us a little bit of story about your stove and maybe some pictures of your stove running, that could help to figured out what could be the problem.
  3. Sparky
    Sparky Subscriber
    Houston, Tx area
    Try bending the arms on the burner plate VERY slightly down to lift the burner plate up a mm or two.
  4. snwcmpr
  5. Sparky
    Sparky Subscriber
    Houston, Tx area
    Do try adjusting the burner plate. Years ago, we discussed the importance of precise spacing between the plate and irifice to achieve th proper fuel/air ratio which gives that blue flame.
  6. kerophile
  7. hornillo
    tarragona
    What kind of fuel?, unleaded gasoline, coleman fuel.
    Greetings.
  8. Tony Press
  9. William Moss Canada
    Québec City, Canada
    Hi JP2. Cleaned it up, everything seems to be in working order though I may need a new gasket on the fuel tank (dixit BernieDawg). I don't want to take it apart until I see if the gasket was the problem or not. Using Coleman fuel. The stove was only used three or four times after purchase (35 years ago) and twice this winter. I cleaned out the nipple with isopropyl alcohol then burned it twice for 20 minutes to clean out any crud there may have been but I don't think it was used enough for crud to build up.
  10. snwcmpr
    I am not sure what your reference to BernieDawg is about.
    Even a new, unused, stove, that old, would need a new filler cap seal and SRV pip. They age and get hard.
    If the filler cap seal is soft to the 'poke', then maybe all is well.
    I would suggest a 'Dunk Test'.
    Cold or room temp stove, empty, put into a container/sink of hot water. Stove turned off, watch for bubbles as the pressure builds when the tank gets hot.
    If the dunk test shows no bubbles, then I would suggest running the stove for some time to 'clean the pipes'.
    If bubbles, order a filler cap gasket and pip.
    Ken in NC
  11. JP2
    JP2 Subscriber
    Canada
    Hi
    The Dunk test is a classic before anything else for safety and understanding. For what concern the flame, I recommend that you read all 3 links above coming from @kerophile if you want to spoil yourself with quality information concerning a blue flame.
    Enjoy
