Radius 250 problem with wire
Discussion in 'Fettling Forum' started by Javerjayal, Jun 22, 2019.
  1. Javerjayal
    Greetings mates I have this problem with wire cleaning spray.
    try to join with soft solder does not work.
    the solder came out through the hole along with the wire
    there is a solution????
  2. Tony Press
    Hard solder (silver solder). I don’t think soft solder will withstand the heat of the burner.
    You could try to crimp it in place.
    Or buy a new needle and rack.
    @Javerjayal
  3. ROBBO55
  4. presscall
    presscall United Kingdom SotM Winner Subscriber
    Yes, the post is HERE
  5. Javerjayal
    how can I solder with silver with that little thing???
    there is a silver burner???
  6. shueilung.2008
    shueilung.2008 Subscriber
    Uruguay
    @Javerjayal : Just crimp it. Do not try to solder with estaño!
  7. presscall
    Alternative is to check the fit of an easily available Optimus pricker rack in the Radius burner.
