Radius No.1 - a change is as good as a rest !
Discussion in 'Stove Forum' started by A A C, Nov 21, 2021.
  1. A A C
    A A C Norway SotM Winner Subscriber
    Agder Norway
    i have had this dilapidated Radius hanging on the workshop wall for a while . It had been clumsily repaired , leaked from around the filler and seam under the tank . It also lacked a leg and burner caps for its replaced silent burner .
    BA313F39-E76E-4BC4-9234-77D57637583F.jpeg B25E4436-93E7-4DB1-AC1B-7A67DDCFFA28.jpeg
    I have several stoves of this type and as it was a fair amount of work to get this old girl back to presentable shape, I thought I’d try a wee experiment .
    I have two BAT stoves with terminal stress cracks on my « what will I do with these « shelf
    I salvaged the legs and put them on the cleaned up tank . I got the stove leak free by basically moving solder around that was already on the tank .
    Wired the legs to a trivet and secured with a jubilee clip (hose clamp) to the tank before soldering to get the angles right . Got these tips from members here . Worked well
    Now the fun bit . As the tank was pretty tatty with scratching and a fair bit of ectopic solder , I decided to paint it . To retain a connection to the stoves land of manufacture, I chose Volvo Penta Marine Motor Green . Being motor block paint it should be heat resistant .
    9E9057D1-46DB-4005-B4C7-45B400B43D6F.jpeg 79B214E6-55C8-40B3-AC24-EAA9BE706663.jpeg
    I am pretty pleased with the result . The rounded legs gave it as sort of Art Deco vibe, a thing I feel the pressure stove milieau has been lacking :lol:
    Makes what is a pretty common and unremarkable stove look interesting
    What do you think ?
    Cheers Alastair
  2. A A C
    Agder Norway
    P.S.
    Two images, just to demonstrate that the old girl isnt a shelf queen :content:
    Can boil aluminium kettles
    AND Copper kettles ! ! A true multi-purpose apparatus :D
  3. ulysses
    ulysses Subscriber
    Manasquan, New Jersey USA
    A real success. A very nice looking stove that lives again!
  4. ROBBO55
    Well done, Alastair! It's cleaned up nicely :thumbup:
  5. E.B.
    E.B. United States Subscriber
    Kittery, Maine, USA
    Excellent effort on your part! I am jealous of your stove and the kettles, as well.
    Well done.
  6. Ian
    Ian Subscriber
    West Yorkshire
    Nice!
    The green and the shiny brass go well together.
  7. Ed Winskill
    I hadn't seen that done before. Once over the first shock, I see that it is a splendid result.​
  8. presscall
    That’s really good Alastair. It puts me in mind of the RM Rambler butane stove.
  9. Scrambler
    Australia
    You have taken a stove of assorted parts and made it uniquely attractive.
    Do make sure you sign it. In future someone will wonder how, and why. At the least they should know who.
  10. hikerduane
    Plumas County, CA
    Turned out very nice, wish I had half the skill.
  11. A A C
    Agder Norway
    Thank you all very much for your kind replies
  12. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    As Ed said, a bit of a shock at first, but it really looks good.
    ….Arch
  13. A A C
    Agder Norway
    Everyone is very gracious .
    Its an idea if you have a stove that is so worn, scratched, dented or clumsily repaired that it will never look good no matter what you do . I suppose larger dents could be evened out with car filler , primed and painted . I must admit I am pretty pleased with the result myself
