Radius No. 21 (early 1920s)
Discussion in 'Radius No:21' started by Tony Press, Sep 9, 2020.
  1. Tony Press
    This Radius No. 21 is from the early 1920s. It has the following features which marks its production period:
    1. Radius before Radius Ltd (formed in 1937).
    2. A. B. Radius Stockholm/Made in Sweden on bottom of tank.
    3. Radius shooting star logo on tank and tin.
    4. Pressure release valve with external seal, straight knurling
    5. Filler cap with Radius Made in Sweden
    6. Non-recessed placement of filler boss
    7. Radius markings on burner.
    The features are consistent with the 1920 Radius No.21 stoves shown here: Radius No.21 - 1920; and
    here: 1920 Radius No 21.
    I pondered about keeping the stove with its patina, but some verdigris needed heavy treatment and the dodgy soldering at the filler cap needed to be redone. therefore there are photos included in this post from both the the pre-cleaning and post cleaning phases of this fettle.
    A
    Steel wind shield with hinged door, slots, and no stamping.
    Additional stamped letters:
    R on tank.
    N on burner.
    Accessories:
    The spirit bottle has small rust holes.
    A Primus nipple remover (Sweden stamped on the other side)
    Pricker with changeable/replaceable pricker wire. Radius SV. Patent No. 42245 (see here).
    The tin:
    The tin needed treating for rust, but I photographed the remnants of the original artwork first. The lid had been painted with silverfrost some time in the distant past, and therefore had no remnants of the original printing.
    Radius is printed at the bottom and there are two stoves, one either side of the handle.
    No. 21
    The Radius comet.
    After treating for rust I painted the lid gold, and clear-coated the inside and outside preserving the remnants of the artwork:
    Up and running:
    Packed away:
    Washers, seals and pump cup from The Fettle Box.
    Once again, the Radius No.21 is a great stove.
    @stejar @OMC
  2. ROBBO55
    Excellent work, Tony.
    It's cleaned up nicely. :thumbup:
  3. Staffan Rönn
    Stockholm, Sweden
    Really nice! :thumbup:
    BR / Staffan
  4. Haggis
    Haggis Subscriber
    Northeastern Minnesota
    Nice,,, thank you for sharing...
  5. OMC
    OMC Subscriber
    Congrats on score.
    Thank you for an excellent reference post. A job very well done with stove and presentation :thumbup::thumbup:.
    Re Stejar's list of types 1 -6 yours is among a few examples that predate his Type 1 (ie the earlier tank lid), nonetheless the tank, this stove might be referred to as "type 1, earliest example". Of the other earliest examples, FYI Sam's shows the tin w/clasp & artwork. FWIW aligning w/your title "early 1920s", the 1920 catalog is 1st ref. to the No.21 and btw one "i had to have" back in the day and I did eventually get one.
  6. Haggis
    Haggis Subscriber
    After seeing your photos @Tony Press , and following the link provided by @OMC , I had to dig out my, (not nearly so nice), Radius 21 for a look.
    Pretty nifty how designs change over time, and then too; how often do parts from a newer stove end up on an older stove? It’s almost as if a single stove, through a number of fettles, can come to represent the entire range of changes...
  7. Ed Winskill
    Stove of Theseus!
