Radius No.7
Discussion in 'Radius No:7' started by Skauvill, Oct 8, 2018.
  1. Skauvill
    Skauvill Subscriber
    Oppland, Raufoss
    Just posting some photos of my Radius No.7 before I sell it. Its a little bit beside my collector area. But it's nice after all. Just given it polish cleaning and repainted the plate om top, with hot paint color.
  2. Tony Press
    @Skauvill
    Thank you. I really like that Radius silent burner.
  3. boknasild
    boknasild Subscriber
    Looks like there is hole on the top of the burner or is it just an illusion ?
  4. Skauvill
    Skauvill Subscriber
    Oppland, Raufoss
    You are right, and still, the burner is brand NOS. I do have a couple of other burner hats, with no hole. Maybe it shouldnt have been there?
  5. boknasild
    There should be no hole there.
  6. Rangie
    Rangie Subscriber
    Could it be used with a wire for holding the cap on, or would it disrupt the vapour flow? :-k
    Alec.
  7. Skauvill
    Skauvill Subscriber
    Oppland, Raufoss
    Cheers!
  8. Skauvill
    Skauvill Subscriber
    Oppland, Raufoss
    Alec, I'm not quite sure. I have lightend up a couple with similar burners, but they have been with more burned shit, so tthe top hat was more fastend on the burner. So I'm not sure what should happens using a wire. Maybe try once in the near future8]
  9. Skauvill
    Skauvill Subscriber
    Oppland, Raufoss
    Boknasild; thanks for letting me now! Then I will change the top hat before selling! :roll: wonder why somebody drilled a hole in a new burner:-$
  10. Tony Press
    @Skauvill
    That top hole could be repaired by silbrazing.
  11. kerophile
    Hi, Like @Tony Press said, but use a small brass plug and then silbraze it into place. Silbraze is great at seeking and filling small gaps and cracks, but less good at bridging holes or bigger gaps.
  12. Skauvill
    Skauvill Subscriber
    Oppland, Raufoss
    Thanks! I will try that when I'm empy with top hats. I do have a couple moreO:)
  13. Skauvill
    Skauvill Subscriber
    Oppland, Raufoss
    On the two new picture the burner has got a new top. No drilled hole on this one.
