Rechaud Simplex
Discussion in 'France' started by keeper_of_the_flame, Jan 12, 2015.
  1. keeper_of_the_flame
    Hi all, I like to show you what I restored recently.
    This little stove I received from France. It is called „Rechaud Simplex“, made by „Flamme Bleue Society, Paris“. They started producing in 1899.
    complete except filler cap
    surface rosty
    wickwheel moveable
    wick still good enough for test burning
    The reservoir is made of brass, some screws aswell.
    The upper grill is made of cast iron, the rest made of tin.
    Mica size: 7 x 8,5 cm
    Wick is 120 mm
    First I did a complete dismanteling. All parts were boiled in citric acid for ½ hour. The rest was made by hand: degreasing, new heat resistant paint and polishing the brass parts.
    After final assemblens it looks much better now.The old wick and mica is still working – although the flame is not pure blue yet.
    The heat of this stove is not overwhelming. 1 Liter of cold water needs about 12 minutes for boiling. But the name says: Rechaud – and that is what is does, once boiling it keeps the temperature without a cover.The „Rechaud Simplex“ was sold in 2 versions; mine is „model A“ and the little more expensive „model B“ came with enamelled chimney.
    Reservoir volume is 1.2 Ltr., that will last for 10 hours cooking.
    Weight is 1.8 kg.
    Size is 29cm hight, 24 cm x 15 cm reservoir. 1421095041-16_b.jpg 1421095026-13_b.jpg 1421095011-12_c.jpg 1421095000-12_b.jpg 1421094975-01.JPG
  2. geneislucky
    Beautiful restoration. Great job.
  3. presscall
    Good to see that arrive here on CCS and a great job you've made on restoring it. I nearly punched the 'buy-it-now' button myself but being overrun with wickies called Beatrice ...
    ... thought I'd best not.
    The Simplex is on page 9 of this catalogue, courtesy of the Ultimheat online resource:-
    Flamme Bleue catalogue
  4. keeper_of_the_flame
    Thank you for your comments.
    Now, there is a mystery that I havend`t solved yet.
    The wheel for turning the wick on my stove is about in the center line. All pictures shown in old catalogs show it much further off the center line!?!
    Any ideas? - maybe they changed that later - past 1930?.
    1421101276-10_position.jpg 1421101297-wick_wheel_1930.jpg 1421101317-wick_wheel_1909.jpg
  5. keeper_of_the_flame
    Thanx John for the ultimheat web link - I have used their site so often, it is of great value for all of us.
    A nice stove you got as well and beautiful kettle.
    Peter
  6. presscall
    I see what you mean about the wick control. That must make the gripper sprockets of smaller diameter on your Simplex than on those illustrated. Makes for better control (finer adjustment possible) with yours, so maybe a later improvement as you say, Peter.
