Recognition
Discussion in 'Stove Forum' started by ton visser, Oct 11, 2019.
  1. ton visser
    ton visser Subscriber
    Wormer, Holland
    Hi, someone gave me a box with some parts.
    I would be much obliged if I could find the next answer, on what stove or stoves should those parts must be used?
    The first one is a burner:
    It has a fixed pre heating cup and holes on the pipe for the inner cap.
    As you can see made in sweden
    The second part is a inner cap with holes in it:
    Thanks for help,
    Ton.
  2. trebor
    trebor Subscriber
    Optimus 205 burner.
  3. ton visser
    Wormer, Holland
    Ok trebor, both the burner and inner cup?
    And on what stove was it used?
    Ton.
  4. trebor
    trebor Subscriber
    This burner is from the 1980s and it's was for Optimus no5.
  5. ton visser
    Wormer, Holland
    Ok, but this pre heater cup seems to be fixed with soldering, not original maybe?
    And the innercup with holes on top?
  6. trebor
    trebor Subscriber
    The inner cup is optimus part no 2180. Used on other Optimus burners from 1980s up to the Hiker + (model 88).
  7. Lennart F Sweden
    Vänersborg, Sweden
    The inner cup is made for use with the burners with inner tube holes like yours but could as well be used on the regular silent burners, it is a common late replacement on many silent stoves and the burner is often found as replacement for old worn out roarers.
  8. kerophile
    Hi @ton visser :
    "However, you will also note from the photos that there are some other small differences, for example, the inner silent cap of the Primus regulated burner has holes on top.There are also holes in the centre up-stand of the corresponding silent burner body.
    I believe this to be subject of a Primus patent, claimed to prevent or reduce the incidence of under-burn."
    from this old thread:
    regulated-burners-i-have-known.8449
  9. Doc Mark
    Doc Mark Subscriber
    @ton visser ,
    Yes, it appears that someone soldered the spirit cup to the burner setup. You do have proper inner cap but now need the matching outer cap, so that your burner can actually work. Here's a photo of such a cap, just FYI:
    Please read all the good stuff that @kerophile has shared. You will learn a ton!! Good luck, and God Bless!
  10. ton visser
    Wormer, Holland
    Thanks for all the input an yes, I have a lot to read.
    Ton.
