Repairing an Optimus 6 - advice needed
Discussion in 'Optimus No:6' started by Matt J, Nov 10, 2019.
  1. Matt J New Zealand
    Christchurch, New Zealand
    image.jpg image.jpg Hi,
    I've inherited an Optimus 6 which is not in working order. I really want to get it functional again. The jet seems to be blocked, can I buy a new one somewhere? What fuel does it use? What should I use to clean it?
    thanks in advance for any advice provided.
  2. Tony Press
    @Matt J
    That’s a grand little stove.
    This is not the same stove (below), but it will give you an idea of the various features.
    Your stove runs on Coleman fuel or equivalent. The jet in the nipple can be pricked with a high e string from an electric guitar (about 0.2mm)
    Svea 123 Disassembly
  3. SimonFoxxx
    SimonFoxxx Subscriber
    New Zealand
    Hiya Matt J,
    If you need some of the guitar E string, to prick the jet, let me know.
    I am a stove person, based in Christchurch.
    Simon Foxxx
  4. Matt J New Zealand
    Thanks for the offer, I’ll see what I can do with the guitar string.
  5. Matt J New Zealand
    Does anyone know if you can get a replacement jet for the optimus 6?
  6. Tony Press
    Do you think there is a problem with yours?
    You can try Fogas.se; or The Base Camp (UK).
  7. Lennart F Sweden
    Vänersborg, Sweden
    A jet blocked by hard residues could often be pricked when it is heated to the point where the soot outside start to produce some smoke - then detach the nipple when it's still warm and clean out any residues inside - if the wick is still functional this would be enough to get your stove running again.
  8. theyellowdog
    I would think it is part 2502 from base camp Optimus Spares Price List
    But you only need a new jet if you are going to regularly use the stove. If you just want it to work clean the jet you have.
    Replacing the wick inside the stove is often worthwhile, but it looks like your stove does not have a nut to help you remove the burner from the tank. It you need to remove the burner assembly you could put it in your vice, between wood blocks, then turn the tank. The wick is cotton.
  9. OMC
    OMC United States Subscriber
    Simon,
    Welcome Matt, I want to emphasize something if it is not apparent.
    You have inherited a rare nickel plated all brass stove
    (to say extremely rare is not overstating it but it is rare sure enough).
    Simon is a stove person.
    You're seeking advice, I suggest 2 things:
    accept any help/advice offered locally and
    consider not to attempt repair yourself just yet, if this is your 1st such repair.
    Brass parts that are seized or just real tight, is an unforgiving situation even for person with the experience.
    If you were to damage the vaporizer (center stem) or any parts, there is no turning back and no replacements available. Exception, you might be able to acquire a functional jet, as you are inquiring about. The filler cap may need attention (expect that) and like the entire stove.. is very easily damaged.
    So what's the alternative… I believe Optimus 1st offered the 6 in the 30s. MANY years later, early 70s, Optimus offered the Optimus Svea 123. The 2 stoves are comparable in every way, except you need not be careful with the 123, it is replaceable and easily repairable. While you admire and contemplate your No.6, you can proceed with acquiring / fixing / using a Svea 123. <- excellent stove, not rare today and every part is readily available.
    Keeping the 6 on a shelf for now next to a user Svea 123 doesn't seem like much of an inconvenience.
    Like any collectible, retaining the "excellent original condition" of your No.6 will not hurt it's value (and it is irreplaceable).
    good luck
  10. Matt J New Zealand
    @SimonFoxxx Hi Simon,
    I know this is a few years past the fact but that little stove has sat in my workshop since my original post and for the life of me I just can't get it to go. It was my wife's great uncles who by the looks of the age must have acquired it second hand himself. I'm keen to clean it up and get it back to functioning for her but now recognise that I don't want to further damage it due to its rarity. Perhaps we could meet to talk about how I may do that? If you are keen let me know and we can sort something out.
  11. SimonFoxxx
    New Zealand
    Hiya there Matt,
    I only just saw this message. I would be happy to help out, if I can. Just send me a private message. Covid lockdown is a pain, no?
    Simon
