Russian Optimus 8R (PT-1) flame escaping from regulator
Discussion in 'Fettling Forum' started by TeeEmPee, Mar 4, 2021.
  1. TeeEmPee United Kingdom
    Oxford, UK
    Hi All,
    I have a Russian PT-1 'Touristy' which I recently received. There is a small amount of flame escaping from the regulator valve (where you put in the on/off spindle). I've circled it in red in the picture. This probably means there is a leak in the washer; does anybody know where I can source a new one?
    Thanks!
    Tom
  2. presscall
    @TeeEmPee There’s no washer in there but a compressible graphite sleeve. Tighten the nut and the leak will disappear. Tighten the nut too much and the spindle will be stiff to turn. An optimum setting to aim for.
  3. gieorgijewski
    gieorgijewski Subscriber
    wrench no 11
    is needed - when stove was (few) first times running...
    Gently tighten...
    "n" times
  4. TeeEmPee United Kingdom
    Oxford, UK
    Thanks very much John and Gieorgiewski - that fixed the problem.
    Much appreciated.
    Tom
  5. SimonFoxxx
    SimonFoxxx Subscriber
    New Zealand
    These are actually very good stoves. I have found mine has a better flame than a regular Optimus 8R.
    Simon Foxxx
  6. pau-i-amor
    pau-i-amor Subscriber
    17190 Salt, Catalunya
    I agree: russian "Tourist" is better than Optimus 8R-
