Screw down burner cap on Optimus 111T silent??
Discussion in 'Stove Forum' started by Martin Brooke, Aug 6, 2020.
  1. Martin Brooke
    Martin Brooke Norway Subscriber
    Norway
    As a new member on Optimus stove nr 2 (only a week after nr 1!) something new came up that I've not seen anywhere on "google", including the forums..... The burner cap on my Optimus silent burner is secured with two small screws! (See photos). (The cap is marked "Optimus", though it's not easy to make out on the pics).
    Anybody seen that before? Does it help date the stove??
    The sticker (fuel types) with the silent burner makes me believe it's a 111T ...but with the more "classic" filler-cap valve. The pump is o-ring, not leather.
    Just thought I'd hear if screws on the burner cap er anything "special"...couldn't see them on the ad, and I only paid 33 dollars (equivalent) for it to use it....so it's not major important. I've got (hopeful) bids in on a 8R and an 8 too.....again to use, not to decorate with.
    Regards to all, in hope of knowledgeable feedback.
    IMG_20200806_134700.jpg IMG_20200806_134456.jpg IMG_20200806_134556.jpg IMG_20200806_134645.jpg
    Martin.
  2. trebor
    trebor Subscriber
  3. Martin Brooke
    Norway
    Cheers for that!
    (For being Norwegian military it's certainly not something I've noticed on any of the many similar stoves advertised here of late.)
  4. Ray123
    Ray123 Subscriber
    New Hampshire, USA
    Welcome to CCS Martin.
    My 111T has two tabs on the outer cap and the 2 tiny securing screws also. I don't think mine is military and don't know how long Optimus secured the outer burner cap using this method. I always thought this was a later design but don't know for sure. Hopefully we'll get some good responses to answer this question.
    The screws are too tiny for me to handle comfortably in the field so I use an ordinary Optimus cap instead.
    Ray
  5. Lennart F Sweden
    Vänersborg, Sweden
    Norwegian army 111 are a lot of different mixes of old and less old stoves and parts, most of it military orders(norwegian and swedish and later norwegian special orders as the CNA burner to replace early burners), but some of it seem to come from civilian market too, and last they filled up shortages with civilian Hiker+ stored as any Fuhrmeister8/Optimus111.
  6. Tony Press
    @Staffan Rönn
    See comments and question above re silent burner cap with screw retainers.
  7. Staffan Rönn
    Stockholm, Sweden
    Hi all,
    Yes the screw down cap is definitely Norwegian military issue. There were also a baynet securement version of the cap. These military stoves saw extensive use and wear, so as Lennart F suggest several parts may have been exchanged over the years and generations.
    If I remember correctly, the screw down solution is earlier than the bayonet solution so my rough guess is that the burner of the stove in this thread was made in the 1980's.
  8. tretrop
    tretrop Subscriber
    Sweden
    Would this be the same Noway burner?
  9. trebor
    trebor Subscriber
    Yes. Norwegian Army.
  10. 8R Pete
    8R Pete United States Subscriber
    New Jersey
    I believe my 111 T also has the burner screws. Will look but pretty sure it has them.
