Sears Primus
Discussion in 'Stove Forum' started by Boulder1, Oct 14, 2019.
  1. Boulder1 United States
    Boulder Creek,CA
    Hi All,
    I bought my Primus stove from Sears in the 1970s, it is a two burner propane camping stove ,the same configuration as the current Primus Profile, (but without the igniter). Folding lid and sides yellow, base grey, two control knobs in front.
    I need to identify the model and number so that I can look for parts.
    I need to replace both control valves, or rebuild them. Each valve is about two inches long, plastic knob on one end , a pointed cone shaped tip on the other end, a coil spring and a black plastic sleeve. I really most need the black plastic piece.
    Any info will be greatly appreciated.
    Mike.
  2. Lennart F Sweden
    Vänersborg, Sweden
    As you describe the general appearance of a lot of models, it should really help with at least one photo or more photos - it could be one of the former blue/grey 1960's Sievert stoves that was re-named Primus with the blue parts painted yellow instead as most common Primus stoves in the 1970's were yellow/orange or yellow/green.
