Shinabro 340
Discussion in 'Shin A Ind. Co' started by angleofdangle, Jan 1, 2009.
  1. angleofdangle
    Although the stove looks in good condition it has 3 or 4 pinholes in the burner tubes, so i may try replacing it with the burner off an Optimus 00, which i believe will fit, if i come across one at some point.
    Alan
  2. Neil B
    On my 340 the burner has a left hand thread, so you might need the riser tube off your 00 as well
    Neil
  3. angleofdangle
    Many thanks for the info Neil. :thumbup:
    Alan
  4. nmp
    Did you ever change the burner on your shinabro? I find myself needing a left hand thread riser tube for my 340 ,after not reading about the left hand thread before attempting to dismantle/destroy it.
    I now have an oval female thread at the bottom first attempt will be the application of pressure in the vice to restore the shape but failing that!!
    Cheers Nick :oops: :oops: :oops: :oops:
  5. kerophile
