Shinabro Royal 400C (and Optimus 111T comparison)
Discussion in 'Shin A Ind. Co' started by presscall, Jul 16, 2011.
    A 'no-brainer' purchase. The ebay seller wouldn't post it, which kept bidding lukewarm, and he lived a couple of miles away from my place of work.
    The Shinabro didn't have its silent burner converter cap, but I found one from a Primus 100 fitted and worked fine
    Packing up ...
    ... packed
    For comparison, I took 'Rustbucket' (an Optimus 111) but fitted with Big Si's silent burner, which I'd been fixing, so Rustbucket became 111T-ish for a while
    Rustbucket
    Big Si's burner repair
    Most obvious differences first. The Shinabro's got a smaller tank; it has a roarer/silent convertible burner; it lacks the Optimus's control wheel controlled cleaning needle and has to have its jet cleaned 'manually' by a conventional pricker; it's BROWN and not a pleasant metallic green; the pot rests on the Shinabro are better than those on the Optimus - more on the benefit of that feature later; the case lid flips right back - again, more on the benefit of that feature later
    A shorter tank of smaller diameter on the Shinabro
    Burners - Optimus pictured first, then the Shinabro's
    I stripped the Shinabro's burner for servicing, and had Big Si's burner in bits to do the repair on it, so compared parts.
    Control spindles - Shinabro's obviously lacking the teeth to fit a pricker rack
    The jet nipple on the Shinabro (left-hand one in each photo) has a flat reverse side to the jet top surface and not the conical contour of the Optimus one, which 'guides' the jet pricker in place. The Shinabro jet nipple also has a dimple around the jet orifice to make it a bit easier to find the hole with a hand-held pricker wire
    Looking at the Shinabro burner, it appears to have been designed to accommodate an on-board pricker rack and I'm pretty sure my example could be modified to take one
    Issues to be overcome to get that modification done are that the Optimus control spindle doesn't fit (the thread's different), and an Optimus jet doesn't fit (ditto) ...
    Continuing to service the Shinabro and with the non-return valve pip replaced - NRV at the end of the pump tube was conventionally 'Swedish', I turned my attention to the tank filler cap, equipped with a safety release valve
    As is often the case, the SRV 'pip' was rock-hard, so wouldn't have allowed the tank to get up to it's design pressure
    There's been a lot of discussion in these columns about the rights and wrongs of SRV servicing, some of which discussion I've indulged in myself
    Safe stove strategies
    Assuming I'd have little chance of obtaining a genuine Shinabro spare tank filler cap, servicing the one I had was the obvious way to go.
    Ah, a 'bottomless' thread - meaning, no positive stop for the valve insert ...
    TO BE CONTINUED
  2. presscall
    Yes, that 'bottomless' thread. It meant that from first engaging the threads to as far as it would go there was quite a variation possible. Consequently, the SRV spring tension would vary a lot too ... so I opted for the valve insert being set flush with the tank cap rim
    In this post ...
    Discussion about Shinabro Royal stove
    Oh yes indeed, Dan, gloriously noisy it is (I like roarer burners to mean it)
    Simmers well though
    The Primus 100 converter cap worked really well ...
    ... but I found a conventional silent burner inner and outer cap worked fine too
    I said earlier that the Shinabro has better pot rests than the Optimus's and that having a case lid that folds right down is an advantage too.
    Demo
    Shinabro pot rests form a perfect rest for a wok, appropriately enough for a stove originating in the Orient. Of course, for a decent-sized wok at least, the wok-friendly pot rests would have little use if it weren't for the flip-down case lid to provide the clearance
    Some might argue that the large-diameter base of a wok would result in an undue amount of reflected heat reaching the fuel tank. It's not proved to be the case in practice. The tank has an efficient heat deflector and the curved contour of the wok base creates plenty of clearance where it matters - which a large diameter flat-based pot wouldn't.
    Just to emphasise how the Shinabro scores over the Optimus for wok cookery, here's why
    At first glance, pot rests that work so well as a firm platform for a wok fail for small-diameter pots
    Not a problem, the pot rests are simply switched around
    Excellent stove, especially if I can work out how to build in a pricker device ...
  3. mr optimus
    mr optimus Subscriber
    Hi John brilliant post and documented photos as usual, the shinabro realy does look a great stove and built to a high quality, the only thing missing to the original 111 is they dont have a built in cleaning needle which is no big deal if the user dont mind or prefers to manualy clean the jet.
    I my self like the look of the pot rests better than the 111 but in your demo it is perfect for wok cooking which beaing a eastern/asian manufactured stove is proberbly designed for wok cooking or larger pots, but not very practacle for smaller pots which make the 111's pot rests more practacle,but still a very nice stove to have i have been looking out for one at a good price for a while once again John well done there on a great score and a brilliant post
  4. presscall
    Thanks for the comments, Brian.
    I've not long ago polished off a chicken stir-fry, courtesy of the Shinabro, which worked great! It's powerful enough for the job, which as I posted here, is essential for a wok-burner
    Good wok burner stoves
    One thing I didn't mention in my original post, and that's the fact that the control wheel has a 'clean' function marked on it. This model most certainly isn't simply a stove with a missing pricker needle as you'll gather from the control spindle design. Presumably Shinabro just picked the control wheel out of the parts bin of another stove's set of parts - one with a pricker function.
  5. mr optimus
    Hi John thank you for the extra infomation on the self cleaning device, and silly of me not too noticing the control wheel with cleaning on it in fact i thought that shiabro only produced stove with out the self cleaning needle i must have a good look in the reference gallery
  6. theyellowdog
    Hi John
    Great post, The shinabro is one of my favourite stoves, probably because it was my first silent pack away. The only think that stops me using the stove more is that it is very awkward to prick.
    I will have to look out for a primus 100 cap as my shinabro cap touches my wok when I use it.
    The inner cap on the shinabro has a down tube, like the one on a phoebus 625. I will post some photos today.
    Dan
  7. theyellowdog
    Here is my shinabro. Things to note, different pump handle to the one above. Holes on the base of the tin are very uniform and I think they are factory done. I wonder if this stove once had rubber feet? I notice Johns stove above does not have the depressions which mine has around each hole. I have no reg handle (sob sob). Mine was brown when I got it.
    I really rate this stove, I once had a shinabro 170gr (8r clone), I now wish I tried the cleaning needle assembly from that in this stove.
    Dan
    1310858427-shinabro_royal_4000c_001_587x440_534x400_494x370.jpg 1310858684-shinabro_royal_4000c_002_587x440_494x370_494x370.jpg 1310858751-shinabro_royal_4000c_003_587x440_534x400_494x370.jpg 1310858817-shinabro_royal_4000c_004_587x440_494x370_494x370.jpg 1310858863-shinabro_royal_4000c_005_587x440_534x400_494x370.jpg 1310858961-shinabro_royal_4000c_006_587x440_494x370_494x370.jpg 1310859237-shinabro_royal_4000c_008_587x440_534x400_494x370.jpg 1310859360-shinabro_royal_4000c_009_587x440_494x370_494x370.jpg
  8. nzmike
    Interesting thing! :thumbup: Ok, an unashamed copy, but that's cool, looks like they did a good job of it. Looks like it goes like a good'un, too! 8) Can the pot supports be turned around for very small coffee makers? My back packing espresso maker is only about 3 inches wide. Wont fit over the stands of a 111.
    Nice stove!
  9. hikin_jim
    Hi, John,
    Another of your wonderfully illustrated "travelogs" of a journey through a stove. Fabulous. I read every word even though I don't own a Shinabro and indeed have never even seen one. Thanks for taking the time to put this together. Exceptionally clear photographs.
    HJ
  10. idahostoveguy
    John, excellent review and comparison. Looks like a mighty good stove that is comparable to many of the swedish types. I'm most impressed with the pot support design. Just swap them and they'll work just fine.
    Have a great day,
    sam
  11. Wim
    Wim Subscriber
    Lovely stove, great photo's! Maybe a 'copy', but with well thought-out panrests, and both 'roarer' and 'silent' options in one stove. Hey, there's no problem with making something good already into something even better! 8) :content:
    Thanks for sharing,
    best regards,
    Wim
  12. Big Si
    Big Si Subscriber
    Nice one John, as always :lol: :lol:
    Si
  13. Admin
    Admin Courtesy of Iani
    As Big Si says.
    Good colour match for the Shinabro, 400c is Plasti-kote, Rust Not, 793 Chestnut Brown, should anyone need to respray them.
  14. Murph
    Milwaukee WI, USA
    This should take care of that problem!
    https://classiccampstoves.com/threads/16339
    Murph
  15. presscall
    A quick trawl through South Korean stove examples in the Stove Ref Gallery shows that all of the Optimus 111-pattern stoves have those wok-friendly pot rests. Convertible burners are the norm too, but not all have case lids that fold flat to accommodate a larger wok
  16. presscall
    It certainly does Mike
    Yes, the pot supports turn around so no problem with that espresso maker
    As you say, Dan, the arrangement's quite different on mine, with this drainage grid in just one corner to cope with fuel/primer spillages or overflowing pots
  17. SNOWGOOSE
    Hi John,
    The Shinabro 400C is an excellent stove, I bought mine from Bryan when he was selling his collection.
    It has a real "roar", in fact the "roar" is greater than any other stove I have.
    I like the design as it is so simple to change from roarer to silent.
    Great post, thanks.
    Rob
  18. nzmike
    Excellent piece of kit! :thumbup: :thumbup:
  19. Bish
    Excellent article, thanks. My 400c starts well but quickly looses pressure. I think it is the SRV pip. I can not find spares for sale so repaired the old one by gluing a disc of rubber to the old one. How did you make replacements? Any other suggestions on pressure loss? Thanks John
  20. Doc Mark
    Doc Mark Subscriber
    John,
    Somehow, I missed seeing this post back when you first wrote it! That stove is flat-out wonderful!! I have to see about finding one of them for me-self! Many thanks for another wonderful report and photos, and for sharing this neat South Korean stove with us. I have grown to love the stoves made in So. Korea, and continue to seek them out, when I can! Take care, and God Bless!
    Mark
