Sievert No5 Heater
Discussion in 'Other Models' started by optipri, Jun 21, 2017.
  1. optipri
    optipri Subscriber
    I have never seen this before. Actually not a stove, only a case to keep one in. Probably for heating purpose when wanting the flame safe parted from flammable items. And of course suitable for cooking too.
    I wonder what kind of stove it was meant for. It is rather high, 65cm and 27x27cm width.
    Made of thin steel sheet and some kind of copper plating. A peep-hole in the front to be able to check the flame and a lid at the lower part to insert the stove in.
    This particular item comes from Spain, might be a model that not was sold in Sweden.
    Bo
  2. z1ulike
    I believe you're right about it being a heater. Very stylish item for sure. It would be nice to know what stove set up originally made its home inside the heater.
  3. Simes
    Simes Subscriber
    Very Moorish, not suprised with Spanish connection.
    Early decorative radiator cover that used to be popular in the UK many years ago.
    Now thinking more for a lamp cover than stove for bedrooms, still heating but shades the light. Pressure lamp or wick?
  4. shueilung.2008
    shueilung.2008 Subscriber
    Uruguay
    Hi @optipri
    The position of the vents suggest something to heat the air, taking the ground level cold air, heating it, and expelling it by the top vents. May be a stove with a heater bowl over the burner?
    A real beauty!
    Enrique
  5. optipri
    optipri Subscriber
    I recently saw another one of this model on the net. It had a Cimsa stove with a long stem and an ordinary stove burner at the top. Question is if Sievert sold it with or without stove? Maybe both.
    I will check id any heater I have will fit.
    I am pretty sure it is ment for a Pressure item.
    Bo
  6. Nicola Francesco Elia
    Nicola Francesco Elia Subscriber
    Hi Bo,
    I've seen another one on todocolleccion with a single burner stove into it, no way to identify the stove looking at the pictures. Obviously this is not a fact, without a catalog image I don't think we'll ever know what was meant to stay inside :)
    Nicola
  7. fyrwokr
    fyrwokr Subscriber
    Bitterroot Valley Montana
    This is similar to the canned heat or Sterno portable heaters. Such as the "Porta-Heat" or the "SportaHeater" and "Tu-N-Wun" camp stove and heater
