Sievert SVEA 123 Stove Fettle
Discussion in 'Fettling Forum' started by SimonFoxxx, Nov 16, 2019.
  1. SimonFoxxx
    SimonFoxxx Subscriber
    New Zealand
    I am fettling this stove, as I have identified a leak where the burner riser screws into the fount. I have counted the turns to unscrew, starting with the spindle over the "1" of the SVEA 123; 7.5 turns.
    To seal the leak, should I use red Loctite #3 to seal the leak, or turn tighter past the "1" ?
    Any comments greatly appreciated.
    Simon Foxxx
  2. dwarfnebula
    dwarfnebula United States Subscriber
    Colorado
    I use permatex high temperature thread sealant. It seals, but does not lock.
  3. Tony Press
    Simon
    Turning past 1 might put the control spindle in the wrong place relative to the windshield.
    I would first try copper or nickel grease. If that doesn’t fix it, clean the threads with solvent to get rid of the grease and use a medium Loctite.
    @SimonFoxxx
  4. Tony Press
    I crossed with @dwarfnebula.
    That stuff sound interesting. I’ll see if I can buy it here in Oz.
  5. snwcmpr
    snwcmpr Subscriber
    I do not recall needing sealant.
  6. SimonFoxxx
    New Zealand
    At the point where the spindle lines up with the 1, ie 7.5 turns, the taper joint does leak. I know this for two reasons. Low power flame on full, and a constant stream of bubbles on the hot water dunk test. I will need to seal with something, to get to performance back. I have an idea that red Loctite #3 is not resistant to fuel, so wiil need to check.
    Simon Foxxx
  7. pyro_P Australia
    Westraya
  8. snwcmpr
    snwcmpr Subscriber
    Before you use sealant ...
    Clean and check the condition of the threads on both the tank and the riser.
  9. SimonFoxxx
    New Zealand
    Fair point, Mr Snow Camper.
  10. SPaul
    The thread is tapered, so I wonder if one could just turn it 1/3 of a turn tighter so it aligns with the screen's window. My thought is after a few wick changes, the hole or might enlarge a bit, or the threads might wear a bit, so they designed it with a tapered thread.
  11. Majicwrench
    Majicwrench Subscriber
    I would use a threadlocker/locktite product, no reason not to. It will hold up well to fuel and heat, you can find those specs on line.
    Do take a good looksee however,, a string of bubble reeks of something more than just leaking past threads.
