Sigg Sigg Sputnik (Sigg Firejet, Switzerland)
Discussion in 'Sigg' started by presscall, Mar 6, 2010.
    Like the group of that era ...
    [url='http://www.google.co.uk/imgres?imgurl=http://www.openmusic.ru/articles-re...mage_result&resnum=6&ct=image&ved=0CBkQ9QEwBQ]Sigue Sigue Sputnik[/url]
    ... the Sigg Firejet has its critics who say it's a triumph of style over substance
    It certainly looks stylish with its bottle of 'brennstoff' ...
    ... and takes a smaller bottle, so becomes a practical proposition for backpacking, at least in terms of light weight and compactness
    There are none of those "is it a blue/red, or grey, or yellow?" MSR pump issues, because there's just the one type and it seems pretty well made, unless brass pumps and nothing less are your thing
    As I set about stripping down the pump, I've made sure that I've got a spares set to hand from CCS sponsor Base Camp
    The pump washer seems the weakest link with a light grade fixing arrangement
    The pump has a gauze filter screen in the pump barrel upstream of the NRV
    The NRV comprises a spring and rubber ball. The bottom pair is set in the handle end of the pump rod and acts as pressure release valve when the fuel bottle's been pressurised enough. It lets out a sort of - delicacy aside - farting sound when that point's been reached. The spring is longer and of heavier gauge wire to ensure that the NRV is activated before it does, otherwise it'd be all farting sounds and no pressurised air in the bottle. Fun maybe, but you'd not get your stove to work
    NRV assembly
    The pump handle's a good design and locks down
    A brass thread insert takes the stove flex pipe
    Over to the stove itself now. The jet nipple, not an available spare from Base Camp, alas. I unscrewed (and refitted) mine very carefully. Cross threading would have been an unwelcome complication, given the spares situation
    Final shot in this instalment. I'll post the remainder as a 'reply' to fit the whole picture set and commentary in. Oh yes, this picture caption. Top's the Sigg jet pricker. Bottom is an equivalent pricker I made up out of a Coleman generator pricker rod. I'll explain why I did that in the 'reply' to follow
  2. lanevitt
    lanevitt Subscriber
    Ahh John.. With the first image you posted there (and congrats to the props dept) I can just hear Captain Kirk telling us of the final front ear, and boldly going where no man has gone before...
    Is he talking of my bomb proof outside bog ??.
    Great stuff John.
  3. presscall
    Ok, the stove's designer intends the jet pricker to be used by removing a sump plug underneath the jet (using a coin, according to the instructions). Here's the Sigg pricker in use ...
    ... and here's mine, first the sump end access ...
    ... then using the extra length the Sigg version doesn't have to clean the jet from above
    Why's that my preferred route? Well, the sump plug relies on a silicon seal. New one on the left, the one it's replacing on the right. I'm not happy risking degrading the sump washer by unscrewing the sump plug each time I want to prick the jet, so I don't go that route
    Here's the sump plug in position
    A few more details.
    The bunsen burner type sleeve valve, intended to enable kerosene or Coleman fuel to be used. I've focused on the 'B' and 'A' settings at top left and right of the picture. The 'A' and 'B' don't relate to anything as far as I can make out, because the 'benzine' setting is where the 'A' is
    Here's the rat-tail cleaner cable that's housed in the generator. It's described as a cleaning wire by the manufacturer but my experiments suggest it's needed as a damper, much like the gauze in a brass stove's fuel feed pipe. Without it, the burner definitely pulses
    A bit of fun with the burner plate. It can be inserted the wrong way up ...
    ... and there's a right way, that produces the correct flame pattern
    Some more details
    The stove folds for storage
    Sigg Sigg Stuff Sacks
    Doc Mark's right, these stoves don't simmer. Stylish though ...
  4. parramethtrol
    parramethtrol Subscriber
    i have a Sigg firejet :thumbup: unlit
    and i also have the 12" single of Sigue Sigue Sputnik Love Missile :oops: ](*,) :whistle: had to you tube it as it's been so long since i last played it Link i don't know what i was smoking back then but it must of been good sh*t for me to listen to that :shock:
  5. theyellowdog
    You could listen to that single many times waiting for a sigg firejet to boil your cuppa.
    Great photos and detailed info John!
  6. idahostoveguy
    idahostoveguy R.I.P.
    Hi John,
    It looks like the NRV in the Sigg was designed by the same stovie as the MSR DragonFly pump designer, or somebody was looking over somebody else's shoulder. :-$
    Wonderful presentation on your Sigg.
    sam
  7. Doc Mark
    Good Morning, Presscall,
    John, what a wonderful report on your Sigg Fire Jet stove!! Well done, Mate!! :clap: :clap: :thumbup: :thumbup:
    Your photos our simply outstanding, too. Again, well done!
    I like the little Sigg, and with a simmering plate in place, it does work to do actual cooking, in addition to boiling water. It's small size, and easy use endear it to me, even though others don't seem to like it that much. I've used mine whilst deer hunting, and it worked very well, indeed.
    Again, great job, John! Thanks for your fine sense of humor, your attention to detail, and your great photographic skills!! Take care, and God Bless!
  8. rsser
    Thanks for the informative post.
    My eyes popped at the C-clip retaining the pump washer.
    Have replaced my washer twice (thank heavens for Base Camp!) and never saw one.
    If memory serves it doesn't come with the rebuild kit?
    Cheers from Downunder,
    Ern
  9. BMurr
    I'm trying to prepare my 20 year old firejet to put back into service for camping. Pump wouldn't work and no sign of that washer, I may have lost it somewhere in past. Leather wouldn't stay on end of rod so I've used a metal washer and cut it on one side to replicate the plastic version. Needed to use a pliers to spread the washer before fitting and to close it back afterwards, a metal c clip will be substituted when I find one some time in future. Last job for me is to replace the 20 year old fuel line. I suspect the brass connection at bottle end is made from two parts but can't figure wether they were pressed or threaded together. If I could figure that I could get a new hose made up and fitted, in meantime I may just put heat shrink around it to dampen any leak that may occur in the line. Alternatively I may cut off hose at end of the ferrules and fit a hose with 6mm internal diameter over those and use circular clamps to fit in place, however it pains me to do this as the line does not leak. I've ordered an optimus Polaris to use as main stove so the firejet will be for straight boiling as it is finicky to simmer.
  10. Mongo
    Broke the stop clip on the fuel tap almost on day one umpteen hundred years ago. Never had much success with my Firejet as it almost always burst into a ball of flame on lighting, resulting in having to clean up a sooty mess. And then I found a gas adapter! It now runs on the cheap gas cans that you buy by the dozen and burns beautifully with no mess. In my mind gas certainly seems the way to go with this stove.
  11. Mongo
    The best mine has ever burned.
  12. m.k.
    Hello Mongo,
    Great improvement. Always struggled with the soot too. Where did you get that gas adapter from? Is it that kind of kit one can buy at ali express for example? Thanks & greetings
  13. Tony Press
    @m.k.
    Old Thread Alert.
    @Mongo does not appear to be a recent visitor.
  14. IvanN
    N.E. Oregon
    I love my firejet. I don't have a stuff sack for the fuel bottle though. I keep mine folded up in a cup so it makes a nice compact kit . I always liked the way it folds up.
    John, a very useful tutorial,one I will bookmark for sure.
    Thanks
    Ivan
  15. Rickybob United Kingdom Banned
    'bout time this thread got a fresh revisiting - a classic early effort with signature style already apparent - firm favourite of mine cos i actually have a sigg and with a good jet too so it runs very well i notice some siggs have a dished perforated washer under the burner and some a flat one, if it makes a difference i could not say
    would i step over a whisperlite to pick up a firejet? would i 'eck as like - but i do take the sigg now and then for a day out but the seals are looking a bit iffy so i would not like to rely on it
  16. Doc Mark
    Greetings, All,
    John's excellent work, and his sharing nature, combine to offer us Stovies SO many feasts of delight, not only for the great information, but for the lovely presentations, too!!! HUZZAH to one of the best of the best here at CCS!!!! Cheers, @presscall , and thank you, very sincerely, for being who you are, and for your stellar work in fettling!!! Take care, and God Bless!
  17. presscall
    @Doc Mark
    Thanks Mark for your generous comments, but like you I'm a modest guy so it's "Aw shucks" from me and "Right back at you buddy' for setting the bar so very high yourself. I'm an imitator and newcomer by comparison.
    Day-to-day, the biggest joy here on CCS is the diversity and numbers of contributors, however frequently they post or what the content might be. Though I'm happy to be a regular contributor and pleased to meet with approval, it's such a pleasure to interact with everyone here and a delight to hear what they have to say.
  18. Rickybob United Kingdom Banned
    you are too modest M - i recall my first teaching post, my then headmaster described me as ''a modest fellow with much to be modest about''
    several weeks later i realized that i been insulted in that snide way those oxbridge types have and i tended my resignation
    no need to blow your own trumpet just accept the acclaim and get on with doing what you do, you are after all a ''colossus amongst stove dudes''
    and that's that. fullstop
  19. Trojandog
    East Sussex
    @Rickybob
    "a modest fellow with much to be modest about"
    Reminds me of some assessments rumored to exist in my Army days:
    "Sets himself a very low standard which he constantly fails to achieve".
    "His men will follow him anywhere, if only out of curiosity".
  20. kerophile
    Hi, I am reminded of the kindly professor who was asked to provide a reference for a notably lazy graduate:
    "You will be lucky to get this man to work for you"
    Honour satisfied....
