Hello all, I recently acquired this stainless steel Sigg Tourist set for $25. The pots and lid are the size for the set for the SVEA 123, not the Coleman Peak 1 which comes with the larger pots to accommodate the larger stove. This came with the windscreen which appears to be different than the Sigg windscreen for the Coleman Peak 1, but I don't have a Peak 1 to test it. Can anyone identify what stove this windscreen might be for?
I may be wrong but I have several of the Coleman stoves - a few Peak 1 stoves and I think there was no specific model they fit. I also have the cookware set and have used that on many different stoves. I use the Coleman cook set every time I go camping and also use a few MSR Alpine sets-the older version. I also have a almost perfect aluminum Sigg Tourist cook set in my apartment I look at every day.
I have 2 different versions of that windscreen. I do not recall all the details, but they are different Coleman stove series. One is the 400 & 508 IIRC. The other ... ??? I did not know that the pots are different sizes.
Going to have to look now. My cook set came with a fry pan as I used it the last time I went camping. Eventually have to get a stuff sack as the original Peak 1 set came in a cheap red nylon bag which ripped and will tear one day.
Coleman/Sigg Windscreens It may be more questions than answers. Mine are somewhere in the bowels of the shed.
@snwcmpr the windscreen on the top right of the picture I believe is the one I have. If it i knew what stove it was for. The only Coleman stove I have is the 533 and it doesn't even come close to fitting that.
For reference .. Here is that photo. I think the 2 I have are upper right and lower left. Image courtesy of hunterstovie
Ok so we have the same one - upper right. Please let me know what stove you have for that one whenever you have a chance to look! Thanks!
@Blueflame111 , Sigg made one of those excellent pot set/windscreens to fit the Bleuet stoves, too. Could your set be one of those? I don't know. All the sets that I have fit the Peak 1, or Model 400, and other such stoves. Some of the windscreens did require some filing to make slots that fit certain stoves a bit better. Not much help, I know, but good luck in your quest for more info. Take care, and God Bless! Every Good Wish, Doc
I've been doing some research and I believe my question has been answered in this link: No.400 10_79 in box, 400 was made 79-84 It believe this windscreen was designed for the Coleman 400 series
