Simmer choke for alcohol burner
Discussion in 'Fettling Forum' started by Twoberth, Mar 27, 2020.
  1. Twoberth
    England
    Hi,
    My Abu Roken smoker shown here works well with my Turm 144, however I like to use the Turm for making coffee while the fish smokes in the cooker. The Abu Roken came with its own 'burner' - basically an empty polish tin.
    The problem with this 'burner' is it runs too hot for fish smoking, and doesn't contain enough fuel to cook through a fat fillet. So I made a choke for the burner using shaped and pop riveted aluminium scrap sheet.
    It works well from full flame to low simmer and then snuff.
    So now I use two burners choked down and running side by side to smoke long fillets.
  2. hikerduane
    Simple, effective. I have a Starlyte stove that uses a ring on top to reduce the exposed top of the stove, basically what you are doing, but you have more adjustability.
