Soldering fixture
Discussion in 'Fettling Forum' started by David L, Apr 23, 2019.
  1. David L
    David L Subscriber
    Skokie, Illinois USA
    This fixture allows you to rotate a stove to the best angle for soldering.
    It allows you to hold the stove securely without denting it.
    You can even turn the stove upside down by simply wiring it to the dowel rod
    To avoid the need for exact hole placement, I drilled the holes slightly oversize and epoxied the pins in place with the stove attached.
    Of course you still need to wrap the stove in wet rags when soldering.
    David L
  2. Harder D. Soerensen
    Denmark
    Geniously well-thought!
    Thanks for sharing @David L
  3. Afterburner
    Good idea! :thumbup:
    Just add rotary head and angle can be adjusted accurately. :content:
  4. MrAlexxx
    MrAlexxx Subscriber
    Good thinking!
    Alex
