SOS, how to rebuild Primus burner 4047
Discussion in 'Stove Forum' started by Tantra, Apr 15, 2019.
  1. Tantra
    I have bought a primus stove burner parts a month ago
    I have no ieda to repair it
    I need a lot parts
    I believe it’s came from primus nr.508 stove
    I need 4002/6132/6158/6124/6153/6112/6128/4347
    Now I have no idea.
    Please help me.
  2. Afterburner
    Maybe burner was used without those 'cleaning needle parts'? Those parts might be difficult to find nowadays.
  3. Tantra
    I think so it’s not easy.they can burn without adjustable.
  4. presscall
    presscall United Kingdom Subscriber SotM Winner
    @Tantra
    Take a look at THIS post involving the repair of one of those burners.
  5. Afterburner
    Yes, tank pressure can be used for adjusting and it should work fine. Also I am not sure if there is no adjusting or is the "adjustment" only for moving the cleaning needle.
  6. presscall
    You're right, it's not really a regulated burner with a reducing valve but a burner with an in-built pricker device.
    That said, the partial insertion of the pricker wire (missing in the example pictured below) in the jet hole has a limited regulating effect - much like that on a Coleman 520 does.
  7. Tantra
    Thank you,I try it.
  8. Tantra
    It’s a good question,maybe it’s really no use for adjustment.
  9. Afterburner
    Here is cutaway for burner that has the adjustment: Regulated burner cutaway
    Burner 4074 does not have same construction.
  10. Tantra
    I believe you
    Do you think the needle can control the Kerosene speed "
  11. presscall
    It can regulate the flame to some degree but it's not good practice to do it. The jet orifice and the needle will wear more quickly. Best to achieve a low simmering flame by releasing pressure from the fuel tank, increasing it when needed by repressurising it with the pump.
    Same flame control technique as with a stove with a non-regulating burner.
  12. Tantra
    I have a good plan just make it no regulator
    Thank you
    Now I am decided how to do it.
  13. Tantra
    E
    v if I can make a magic needle
    Same as Optimus nova.
