Hi you Guys. I Found this stove today in a abandond old house and i would like to give it a second chance at The camp Life. My issue is i dont know anything about this stove and if it’s even possible to buy parts for it, also i Think it’s missning a cap of sorts on The burner Anyone out there who Can help me out Tanks Rico ✌
Hi @Rico Horn Welcome to CCS. Fettlebox, operated by the CCS owner, can supply a set of new seals/washers and replacement inner and outer caps for your silent burner: Stove Parts - The Fettlebox Best Regards, Kerophile.
Hi, I think you will find that the pump on your stove is essentially the same as that on most No.1 pr No.5 classic pressure stoves. Typical pump assembly Best Regards, Kerophile.
Welcome. That is one solid looking unit. Take your time. Look forward to seeing the restored stove pictures. Good luck. Iain
Thanks Yes it dies looks very solid, i have started to take it apart and The NRV works just fine. So before getting in to polishing and so on i Think i ned to have at test start up do you Think it’s possible to find some video material on how to fire it up. I am at complete rookie haha Ps. Does it run on gasoline og petrolium ?
Hi @Rico Horn Fuel is strictly Kerosene only. Here are some good instructions/ explanation for operating pressure stoves: You do need inner and outer burner caps BEFORE you can operate this stove! You can see them in the link to Fettlebox I provided earlier. Stove Lighting instructions Any other questions, be sure to ask. We all had to start somewhere. Best Regards, Kerophile.
