Spirit can for Primus 210
Discussion in 'Fettling Forum' started by Twoberth, Oct 9, 2020.
  1. Twoberth
    England
    I have posted before about making spirit and fuel cans. This is a relatively easy spirit can to make to fit in a Primus 210 or similar tin.
    A small tomato puree tin is the starting vessel, as it fits perfectly in the tin.
    First cut the top off using an old type tin opener so that the rim is left on.
    Empty and rinse, then burn off all the plastic decals and inside coating. Make a top from steel sheet and drill a 10mm hole.
    Cut off the threaded area and from a 10mm compression fitting body, and slice the top off the nut.
    Silbraze the threaded area over the hole in the steel top and then solder the top into the body. Also solder a brass cover on the nut.
    Fit suitable washer into the brass lid and you should have a leak tight container.
    It pours well, and looks at home in the Primus 210 tin.
  2. BradB
    Central North Carolina USA
    Very nice! Good skills. Brad
  3. JP2
    JP2 Subscriber
    Canada
    Look good. Bravo
  4. Marc
    Marc Subscriber
    Oregon, USA
    Well done! Functional and looks just the part.
  5. ajvuik
    ajvuik Subscriber
    Netherlands
    Looks good! Have fun with your own creation. It is stuff like this that makes things our own.
