Stamped on Coleman Tank: meaning?
Discussion in 'Stove Forum' started by Tony Press, Aug 20, 2019.
  1. Tony Press
    This is stamped on the tank of an Australian-made Coleman suitcase gasoline stove:
    It reads:
    IMPORTANT
    Never Use Ethyl
    RDCPED Gasoline
    At least I think the letters say “RDCPED”.
    I am speculating that the “Ethyl” refers to a proprietary fuel additive for converting pure gasoline to leaded fuel (but I don’t really know). But I don’t have any idea about the letters below.
    Any help gratefully appreciated.
  2. Greeley
    Stillwater Minnesota
    Tetraethyl lead. Sure to clog your generator and burner!
    Tom
  3. snwcmpr
    snwcmpr Subscriber
    Can you rub a pencil on paper placed on the letters?
    Ethyl also referred to Premium gasoline when I was a kid.
    Regular or Ethyl.
  4. Barrett New Zealand
    Northern New Zealand
    Hi @Tony Press
    Last line should read
    OR DOPED GASOLINE
    Barrett
  5. Lennart F Sweden
    Vänersborg, Sweden
    Before lead was common in gasoline, ethyl could refer to ethyl alcohol that was mixed in for rising octane and sometimes to stretch a limited oil supply - it has been a common practise again nowadays but is just named common or automotive gas today. Those fuels could be very volatile if pressurized and forced through a nozzle without burning off at once - could easily cause fireballs or explosions on some stove types.
  6. Barrett New Zealand
    That makes sense to the word Doped, sort of like doping a horse to increase race performance.
  7. Tony Press
    Great! Thank you @Barrett
  8. Tony Press
    @snwcmpr
    The letters are worn because of the way the tank had been transported it the suitcase.
  9. cottage hill bill
    cottage hill bill Subscriber
    Not alcohol, tetraethyl lead as Tom pointed out. That was the early gas additive. The American version would read "White Gas Only". White gas was the term for gasoline with no additives, ethyl was the anti-knock, more expensive stuff.
