The photos shows my Høvik verk Standard 23. "Under recovering" The fuel tank has a lot of dents and bulps, but not much to do about them. I put it away for now, but later I need to make a new cocer to set into frame, as a cover under the burner. I needed to put an Optimus burner on it, but I guess the right burner are the same as the one on Standard 31. It will easly show up.
Hi, very similar cast frame to Gloria and Lux, but with Comet/Primus style decoration… interesting mix Nicola
@Skauvill Hei på Toten . Really interesting project . I can maybe help you with a Standard 31 if you need the burner . DM me if you are interested . Cheers Alastair
Nicola Francesco Elia I am not that familiar with iron frames at stoves, but thank you, I will check it out!
