Steel tank regulated burner
Discussion in 'Mystery Stoves' started by Admin, Apr 24, 2012.
  1. Admin
    Admin Courtesy of Iani
    One to be identified sometime.
    The tank, legs and spirit cup are steel, interesting little spirit cup, the pot stands are made of brass.
    There is a hexagon nut non return valve, in the bottom of the pump tube,working ok, so not touching - no tool to get it out !
    As in the opening description, it is a regulated burner, very controllable three tube burner, its just a simple screw in/screw out spindle - much the same as on some early meths stoves, no rack/cleaning needle.
    No heat seals required, the spriggett compresses between the riser tube and the inside of the burner nut.
    The tank capacity is about 1 3/4 pints.
    A very well made stove, by whoever.
    1335283238-IMG_5329_opt.jpg 1335283263-IMG_5330_opt.jpg 1335283289-IMG_5333_opt.jpg 1335283313-IMG_5349_opt.jpg 1335283341-IMG_5351_opt.jpg 1335283362-IMG_5350_opt.jpg 1335283388-IMG_5352_opt.jpg 1335283418-IMG_5347_opt.jpg 1335283443-IMG_5336_opt.jpg
    1335283081-IMG_5324_opt.jpg 1335283111-IMG_5325_opt.jpg 1335283128-IMG_5326_opt.jpg 1335283146-IMG_5327_opt.jpg 1335283169-IMG_5328_opt.jpg
  2. theyellowdog
    The bird's stove Hi The Bird posted a similar stove purchased here in NZ
    At the time I had no clue what it was however I have seen a few Aladdin stoves with the same reg handle since then.
    Did you buy this from Aussie? Could it be Aladdin?
    Dan
  3. Admin
    Hi Dan
    It flew in from NZ this morning. Thanks for the link.
    Ian
  4. presscall
    Cast the net wide for this one Ian. Ebay Oz I think?
    I'm guessing it's of Australian manufacture.
  5. Admin
    Having read The Bird's thoughts about the stove, I can't see this being austerity. Brass legs, regulated burner, it is a stove with total quality - not what I would expect during an austerity period.
    Not even the early steel Primus stoves come close to the quality of this one.
    The tank and legs bear a resemblance to an early Primus 216. The spindle and the control knob, again bear a resemblance to the Campingo Nos 1 & 2. The 3 tube burner is very similar to the German Kunze Karat 90 and others.
    Just a thought on timeline - 1930s ?
    1335529927-IMG_5379_opt.jpg 1335529945-IMG_5380_opt.jpg 1335529980-IMG_5386_opt.jpg
  6. The Bird
    The Bird Subscriber
    Hello Iani,
    Yup, she's a sister to my Ol' Girl, but with her clothes on. I'm glad you appreciate yours as much as I appreciate mine. Enjoy using her, she'll deliver every time. I never fail to smile when I light my Ol' Girl up. Good luck finding out her name and her pedigree, I'll be watching with interest.
    Best regards,
    Mike.
  7. Admin
    Hi Mike
    When I first saw her on Ebay NZ, I thought, umm, this looks nice. I am not sure whether it is a passion I feel, or a lust for the stove. Whatever the feeling is, this stove has got a lot of class.
    Ian
  8. theyellowdog
    Hi iani, Do you think this burners thread will fit a 1 pint stove. The thread on mine is clearly smaller than a 2 pint burner. I have one of these burners and am not sure what to do with it?
  9. Admin
    Hi theyellowdog
    Found the stove today. No, the burner thread won't fit a 1 pint stove, or any other European stove, come to that. If I find out any info I will PT you. Keep the burner, it is rare.
  10. theyellowdog
    Thanks for looking.
