Svea 123 Optimus 8R and 99 fuel tank cap
Discussion in 'Fettling Forum' started by Steve Sklueff, Mar 13, 2019 at 10:50 PM.
  1. Steve Sklueff
    Does anyone know what tool to use, and where to find one, so I can access and service the pip seal?
    Thank you!
    Steve
  2. Four Smokes Wallup
    Four Smokes Wallup Subscriber
    Canada
    Hi Steve, welcome.
    A fellow by the name of BernieDawg has made a couple of videos on You Tube explaining how to take apart and put together these SRV caps (SRV = Safety Release Valve).
    If you have a cheap screwdriver available or can buy one, the next step is to make a notch with a file in the middle of the blade to allow the blade to enter the slot without making contact with the round thing in the middle of the cap.
    Alternatively, you can purchase new Optimus SRV caps / tank lids on Ebay if you’re not confident, or if there is a CCS member living nearby your location, they could volunteer to do it for you.
  3. JP2
    JP2 Subscriber
    Canada
  4. Four Smokes Wallup
    Canada
    Good to know about those two options also, @JP2
  5. SveaSizzler
    Tucson, Arizona
    I have a Svea 123 [1970] that also has the slotted SRV cap. Is the pip the same as the caps with the pentagonal fixture?
    Steve, if you decide to just buy one, they can be had from www.base-camp.co.uk or fogas.se.
    I have bought parts from The Base Camp and they are reliable. Fogas did not reply to my email querry about Svea/Optimus parts, but it wasn't in Swedish.
    The Fettlebox sells the soft seals, but not the hardware parts.
  6. JP2
    JP2 Subscriber
    Canada
    Hi @SveaSizzler
    When I did mine , I have burned the cork pip that was in and replaced it with the one you are talking about and it was a little bit narrower but still did the job.
    Please, if you open yours , can you give me the length of the spring for my reference. I want to compare it with another cap. Thank
  7. SveaSizzler
    Tucson, Arizona
    Since the cap works OK with a fresh fuel gasket, I haven't replaced the pip. When I do, I will remember to measure it for you. Do you want Metric or Standard [inches]?
    I haven't selected which slotted screwdriver to sacrifice to make a special tool. Since Sears is going under, I can't take the cut up one back for a fresh tool anymore.
    Did you say the OEM piece is cork? Did it scorch when you hit it with a gas torch to loosen the threadlocker?
  8. JP2
    JP2 Subscriber
    Canada
    Metric. You probably know that if the washer was try, the pip is dry. Funny thing about it is as soon as I have burned the pip when I was heating the tread, the plunger went in and I could unscrew it with a regular screw driver.
  9. JP2
    JP2 Subscriber
    Canada
  10. JP2
    JP2 Subscriber
    Canada
    Here is the inside.
    As you can see the spring was not good anymore.
  11. Four Smokes Wallup
    Canada
    @JP2 , what source do you get new springs from when the old spring is kaput, please?
  12. snwcmpr
    snwcmpr Subscriber
    Here, not There
    One of the ideas that came from research of the Svea 123, on this site, was that the whole caps did not need to be replaced to fix the SRV or filler cap seal. That may have possibly been the thought when the stove was sold, but not any longer. These are classics that only require a few simple fettling talents.
    Quite often the NOS cap would require the same replacements as the cap that the owner has. Thus, no help at all. A new cap would have its own set of problems.
    Research on this site over the years has resulted in knowledge of how to replace the seals of the various caps. The cap shown is one of the easier to fix the SRV.
    That said, simply replacing the pip and seal is a straightforward fettle. Well done.
    Ken in NC
  13. Four Smokes Wallup
    Canada
    @snwcmpr, I wasn’t talking about NOS. I was referring to current manufactured lids for the Svea 123R and Hiker+ which fit previous 8Rs, 99s, and 111s just fine. It makes sense if the original non pressurizable cap is missing and 2 available pressurizable caps in my first 8R were damaged by previous owner(s) beyond safe repair. Otherwise, I would have fettled them in the best CCS tradition.
  14. snwcmpr
    snwcmpr Subscriber
    Here, not There
    And putting a new, made in India, hood on a classic 2 Door '57 Chevy because it needs a seal refurbished?
    I referred to NOS & New caps.
  15. JP2
    JP2 Subscriber
    Canada
    Is it as slotted cap Harry? Can I see the spring?
  16. Four Smokes Wallup
    Canada
    No, it was one of the hex socketed current manufactured tank lids by Katadyn and has performed as expected. I saw no reason to dissassemble it after checking the resiliency of the inner seal.
  17. JP2
    JP2 Subscriber
    Canada
  18. Four Smokes Wallup
    Canada
    Sorry, I was under the impression you had referred to NOS only. My object was a functional stove, which was achieved and continues to perform well to this day. The tank lid I got was right from Katadyn.
