Svea 123 pump cap
Discussion in 'Fettling Forum' started by Doug L, Mar 14, 2021.
  1. Doug L
    Doug L Subscriber
    USA
    Wondering why this cap won’t work. I put a new cap gasket and a new pip on it. The pump I know works great with a different cap so I know that’s not the problem.
    Any idea? 06AA58EA-1CD6-4819-B92D-5FB1063365A5.jpeg 186C04B3-BB1A-4194-8DEA-F6987B50B452.jpeg
  2. hikerduane
    They can still leak. Have you pressure tested it?
  3. Optimust
    Hi @Doug L
    Do not know if this helps, I have read in the forum, when other fetters changed seal & pip, they made a point of counting the turns of the grub screw as it was removed. Could it be too tight when refitted. A guess @ best, hope you resolve
    the problem. Best Regards, Optimust. O:)
  4. presscall
    Won’t work in the sense of not allowing the tank to pressurise/hold pressure Doug, or not allowing the pump to shift air through it? If the latter, @Optimust has made a good point.
  5. hikerduane
    Can you push air thru by holding the joined cap and pump or does it get difficult?
  6. Doug L
    Doug L Subscriber
    USA
    So I don’t think I have a wrench to fit that 5 pointed screw on top but I was able to get working by loosening the spring sleeve. Who sells the wrench for that screw?
  7. Tony Press
    @Doug L
    Those penta-wrenches are hard to come by. Don’t use a 5-pointed “star wrench” as these have been known to round out the brass. Some folk around here have made their own penta from a hex wrench.
    Look through this thread to see the cap taken apart.
    Disassembly and reassembly of Optimus No. 199 (Ranger)
  8. CW
    CW United States Subscriber
    check this link it has the best info on the pump cap, sorry you will have to cut and past into the search box.
    Hidden secrets of the Optimus 8R mini-pump cap revealed!
  9. Tony Press
  10. CW
    Thanks
  11. Doug L
    Doug L Subscriber
    USA
    Thx guys
  12. snwcmpr
    So, what does it not do?
  13. Majicwrench
    Majicwrench Subscriber
    Looks like somebody has already had it apart...
