Svea Campus No.2
Discussion in 'Campus No:2' started by Jan Bjørndahl, Aug 27, 2021.
  1. Jan Bjørndahl Norway
    Norway, Oslo
    I just found this stove in my fathers basement, it comes from my grandfather and was probably used in the 1920/30s. There is no markings on the stove or the box. The small fuel bottle is marked with "Sievert" and the small nozzle pricker is marked with "Radius".
    Any information about this stove would be great! Is it possible to date these stoves?
  2. OMC
    OMC United States Subscriber
    WELCOME Jan,
    Thank you for posting it.
    As well as the spirit bottle the burner says SVEA (aka Sievert).
    It's impressive and is looking like it is a Sievert model.
    If knob slides off, the entire "works" may lift out of the case.
    If so you will have to look very closely at tank before saying for sure there is no markings on it.
    IF the tank has no markings (i think it will), then, this would be a bit mysterious imo, as "Sievert/SVEA" is typically found on their tanks etc.
  3. ally
    ally Subscriber
    Lincoln, UK
    nice!
  4. Jan Bjørndahl Norway
    Norway, Oslo
    Thank you! Makes it easier to search for the model number :)
  5. Jan Bjørndahl Norway
    Norway, Oslo
    I thought the SVEA mark was just a short for Sweden ;)
    The knob is stuck, can't turn it or pull it out. The tank is secured with 3 screws that also are stuck.
    Will update once I'm able to loosen them and can inspect the bottom of the tank!
  6. shueilung.2008
    shueilung.2008 Subscriber
    Uruguay
  7. OMC
    This was already solved, someone had suggested Campus but deleted the reply.
    It is a Campus, a more rare early Campus 2.
    I looked at later Campus 4 & 5 in gallery and went to catalogs looking for your burner and found the No.2.
    (now as i type, i see Enrique has it right)
    No need to disassemble just yet.
    re markings on the tank, credit member pinky re early Campus No.2
    "I was surprised to see that the tank and cap have no engravings at all." source
    CONGRATS !! nice stove
  8. snwcmpr
    Be careful. This is a stove worthy of care.
    Best you research so you do not break anything.
    Well done.
  9. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    +1 with @snwcmpr
    Soak the screws in penetrating oil before trying to remove them.
    ….Arch
  10. Lennart F Sweden
    Vänersborg, Sweden
    That style of burner valves use to get stuck when they are not used for a long time - very often they will work fine if you first oil the spindle, then heat the burner jet area until the oil on spindle start to boil, then open and close the valve several times and oiling the spindle during cooling time.
  11. Lennart F Sweden
    Vänersborg, Sweden
  12. Christer Carlsson
    You probably got it correct there!
    Thread is now moved to the Reference Gallery, and title changed.
  13. hikerduane
    Yes, I got mine from a member here, his was posted in the SRG, correct meths dispenser also. Works great.
  14. Jan Bjørndahl Norway
    Norway, Oslo
    Thanks for all the replies and information I've gotten! This site is awesome :D/
    My father suggested to soak the bottom of the stove in diesel to loosen up the screws.. is this a good way to go? Could I soak the entire stove this way?
    PS
    This site should come with a warning sign... The collection of stoves is highly addictive!
    Upon learning more about the stove I found, I started looking through ads for stoves and ended up buying one HV Standard no 41 and a Radius no 21 stove :lol: They are both in bad condition so I will make a new post with pictures and ask for some fettling advice for them as well!
