Svea No 15
Discussion in 'Svea No:15' started by Hugh_Manatee, Mar 21, 2019.
  1. Hugh_Manatee
    Hugh_Manatee Subscriber
    With things as they are, I want an emergency cooking facility. Why not sort one of the ones in the loft? I would have got these stoves from the bay years ago. I'm afraid I don't know the age. The filler cap detail was broken before I got it. This cap is very tight down to I think the seal. This will be replaced.
    Trade mark engraving:
    Is this a sort of flame spout? Does it take the last bit of flame from the priming tray and deliver it to the burner?
    Hopefully we will have a flame shot in due course. If I hold my thumb over the filler hole and pump, it build pressure quite nicely.
  2. kerophile
    Hi @Hugh_Manatee I look forward to seeing your Svea No15 operating. You are quite correct in your assumption about the patent “igniter” fitted to your stove. See a similar one here:
    Svea No.15 - 1930s *
  3. igh371
    Durham
    Hi Hugh, the markings and font style on your Svea No.15 indicate a date in the early to mid 1930s Earlier Svea had used a very distinctive 'bubble writing' font and in the later 1930s they adopted a new badge and the 'King of Stoves 'logo(e.g.). I am a great fan of the Svea flame 'leader' which acts as a very efficient lighting mechanism for when the main priming charge is just about burnt out. An exceptionally practical stove for reliable everyday use.
    Ian:thumbup:
    @Hugh_Manatee
  4. Radler
    The pump knob looks very much like a knob with travel cap parked on it. The knurlings at both ends helps to screw the cap off. I presume, the plunger came from a collapsible stove. Usually such caps are missed where they should be, here it is the contrary.
    Radler
