Svea No.5 pre-WW1
Discussion in 'Svea No:5' started by igh371, Jun 7, 2016.
  1. igh371
    One fairly early Svea No.5 still with the illusive original silent coil burner, although, as usual I have had to fabricate a replacement top cap. 'NYBERGS PATENT SUNDBYBERG' pump cap and early type pump rod point to a date c.1908 or not long after. The base provenance stamp, however, with 'MADE IN SWEDEN' in the centre rather than a simple 'PATENT' precludes it from being even earlier.
    DSC04249.JPG DSC04254.JPG DSC04250.JPG DSC04248.JPG DSC04247.JPG DSC04255.JPG DSC04253.JPG
  2. Tony Press
    Excellent and beautiful.
    :thumbup:
  3. igh371
    Testing another form of replacement burner top cap. This one is made from a 1950s Land Rover 2 litre petrol engine core plug* which have just happened to discover has an absolutely perfect inside diameter to fit to the No.5 snake-coil tube burner top. The core plug gives a flat top, closer in configuration to the original than the domed modern large size silent burner outer used initially. It also seems to give a better flame. The material is a fairly thick stainless alloy which seems handle the heat well.
    * Land Rover part number 236998.
  4. shagratork
    Amazing! :clap:
