Svea not burning correctly.
Discussion in 'Stove Forum' started by Rob Carignan, Nov 17, 2020.
  1. Rob Carignan United States
    Portland, Maine
    I took my Sea 123 camping this weekend and it burned horribly. The flame was high and yellow and it sputtered. When I turned it off, it remained lit so I had to blow it out.
    I picked up this Sea last fall and have since disassembled it, cleaned it, replaced the with with a cotton mop string and I am using Coleman camp fuel.
    Any insight on how to get it to burn clean?
  2. presscall
    @Rob Carignan Underprimed? - yellow flame, residual unvapourised (wet) fuel remaing lit when regulator spindle closed.
  3. Rob Carignan United States
    Portland, Maine
    Hmmm. Perhaps I'm not priming properly? I warmed the reservoir with my hands and when I open the kindle fuel came out.
  4. presscall
    @Rob Carignan The concept’s ok (though I use alcohol for a cleaner prime) but you need to shield the stove from draughts - the built-in windshield isn’t always enough. The primer cup should be as full as you can get it without it spilling over.
  5. Ed Winskill
    In cool weather I always double prime; it often is needed.
  6. Rob Carignan United States
    Portland, Maine
    Well, I primed and the fuel came up very quickly. Big yellow flame and sputtered. I'm having trouble posting a video.
  7. presscall
    @Rob Carignan
    Well, it surely points to a shortfall in full vapourisation. With respect to your skills in replacing the wick, the ‘fit’ of the wick in the burner riser can make a difference. Too slack and fuel will pass to the jet too rapidly, losing out on vapourisation.
  8. Harder D. Soerensen
    Denmark
    +1 on Johns remarks concerning the wick - but even the smallest fragtment can clog the jet - especially after fettling the wick when small pieces can be turned loose, so I would prick the jet next time it sputters, just to be sure.
    A piece of glassfiber string or Carbon felt in the little priming cup will give you a much better preheat even in colder weather.
  9. Rob Carignan United States
    Portland, Maine
    Thanks, I'll drain the fuel and check the wick.
  10. Rob Carignan United States
    Portland, Maine
    Hey, I think I figured it out. The nipple or jet wasn't screwed down tight and fuel was seeping up through the threads. It seems to be burning correctly.
  11. Rob Carignan United States
    Portland, Maine
    I spoke too soon! It works great BUT the spindle is off track and I couldn't shut it off. I blew it out and put it out in the cold to cool and depressurize.
  12. kerophile
  13. Rob Carignan United States
    Portland, Maine
    Thanks. I broke the needle last night. That's why it wouldn't shut off. Drag.
