SVEA SIMPLEX Nr 3
Discussion in 'Svea Simplex' started by anfeng, Nov 5, 2018.
  1. anfeng
    anfeng Subscriber
    This is a beautiful household stove. Observing its various parts, it can be seen that its materials and workmanship are very good. The photos below are like when I bought it.
    The first step is to completely disassemble.
    Then I did some necessary cleaning work. After I cleaned the burner, I found that there was trouble. There were many cracks in the welding place of the burner.
    The two thin tubes and the middle thick tube have different degrees of cracking. I re-welded them with a flame spray gun and some brazing with a silver content of 5 percent.
    After the burner is welded, I have to deal with a bigger problem. The gear of the valve stem is broken. I can't get it because of the Svea burner accessories, so I have to find a way to fix it.
    I first weld some brazing solder in the place where the teeth are broken, and then re-crack the gear with a file.
  2. anfeng
    anfeng Subscriber
    Then I put the valve stem into the burner and put it into the needle for running test.
    After confirming that it was working properly, I started assembling the burner and installed the burner on the furnace. After replacing all the fluororubber sealing elements, I reignited it.
    Beautiful blue flame
  3. jinqi Hong Kong
    中国
    It’s so cool, thanks for sharing.
  4. kerophile
    A beautiful stove and you have great fettling skills,
    Thank younfor posting.
  5. presscall
    presscall United Kingdom Subscriber SotM Winner
    @anfeng
    Lovely stove, great photo documentary and excellent repair work.
  6. Afterburner
    Excellent repair work! :thumbup: Control spindle 'gear' fix is awesome!!! :clap::clap:
  7. redspeedster
    redspeedster Subscriber
    County Durham
    Excellent fettling and a quality stove.
  8. Aleks-S
    Really perfect work! :thumbup::clap:
    Thank you for publishing in details!:)
  9. Tony Press
    @anfeng
    Excellent work on a very good stove. :thumbup::thumbup::thumbup:
  10. teckguy_58
    Washington USA
    @anfeng
    You did a wonderful job of repairing your stove.
    Your fettling skills are excellent.
    Thank you for sharing.
    Norman
