Tank shield
Discussion in 'Fettling Forum' started by john watson, Feb 24, 2021.
  1. john watson United Kingdom
    north shields
    16142047433693680967464546516907.jpg Hi I have s 111b im tidying up and the tank shield is slightly pitted in areas.....can I polish this up or will it damage the plating.....or is it stainless?
  2. Metropolitantrout
    Santa Cruz, CA
    If you polish it go light and go easy as the plating is thin.
  3. john watson United Kingdom
    north shields
    Thought it might be stainless!! Thanks for that.
  4. Geoff Chirnside
    Geoff Chirnside Subscriber
    New Zealand
    You have already got that looking pretty nice.
    I polished mine up a bit the pits and discolouring remain for ever unless its re-plated.
  5. john watson United Kingdom
    north shields
    It was pretty bad Geoff.....it'll get worse now as I've probably taken some plating off. Never mind, its just cosmetic..... the pot support legs are pretty rough, wouldn't mind new ones.....thanks Geoff
  6. William Ritchie
    San Diego California USA
    watch For those who would like to do small batch nickel plating . This will work for all
    parts . WR
  7. Metropolitantrout
    Santa Cruz, CA
    Great video.
  8. Geoff Chirnside
    New Zealand
    @William Ritchie thank you so much for the link to that video.
    I think I will definately look at getting set up myself.
  9. john watson United Kingdom
    north shields
    Wow thats great.....thanks
  10. William Ritchie
    @john watson , @Geoff Chrinside , There are many other tutorials on the same subject . Nickel , Copper , Zinc , electrolytes are all made by the same method . If you are going plate steel with copper , nickel plating first is advised . Good stuff , I have done many firearm parts this way . I have an Optimus 80 tin that I am going to try to Nickel but need to get it soda blasted first , should yield a satin finish , I Hope. WR
  11. William Ritchie
    , In the video I was surprised to see the uncovered hands . In actual practice I would advise gloves . Just saying . Good Luck have fun with it . WR
