Tin-smithing a circular spirit can
Discussion in 'Fettling Forum' started by Twoberth, May 8, 2021.
  1. Twoberth
    England
    It has been pouring down all day here, but the postman brought me some tin-plated steel so no more need to recycle syrup tins.
    This is a copy of a Primus 1738 spirit can, but slightly larger so it does more primes. (35mm x 60mm)
    The circular ends are formed over the steel block, and then the body is bent into a cylinder and fitted inside the ends. Ends are soldered first, then the long seam then the filler cap.
    Fitted with paper decal, and shown next to the smaller No.1738
  2. Murph
    Milwaukee WI, USA
    Well done! Excellent job on the flanges on the end caps!
  3. Twoberth
    England
    Thanks @Murph
    The rough formed flanges were about 3mm, and then cut down to 2mm and as parallel to the ends as I could get them with tin snips. Then they are lightly formed again to give a tight fit around the cylindrical body ends.
  4. Ian
    Ian Subscriber
    West Yorkshire
    Excellent work, as usual. :)
  5. nmp
    @Twoberth Oh no! you may have set me a challenge! Nice work and especially the soldering did you use just the iron or a blow lamp as well?
    Nick
  6. Twoberth
    England
    Thanks Ian and Nick.
    I used a soldering iron for everything this time. A blowlamp produces too much heat tinge on the new tinplate.
    The challenge is on Nick! I also made a funnel from the off cuts and some rusty tubing.
  7. nmp
  8. ROBBO55
    Looks good :thumbup:
  9. Lance
    Northwestern Illinois
    The trick to soldering tubes to flats is to make the tube first then set the tube on the flat bit. Of coarse you have cleaned everything so it will solder easy and even maybe tinned it first. Regardless, make sure the flat bit is larger than the tube enough that you can set the solder iron on the flat bit and against the tube. This is done so the heat will travel into the joint and then apply the solder to the joint not to the iron. This gives a nice small solder joint without a lot of overflow. You can then trim the flat bit to the size of the tube and file (carefully) to make it round.
    IIRC I have shown such a process in the fettling forum back in the day before I went away for a spell.
    Lance
  10. Haggis
    Haggis Subscriber
    Northeastern Minnesota
    Well done indeed…
    I’m impressed with myself when I make a simple windscreen from a piece of roof flashing…
  11. Lance
    Haggis said: I’m impressed with myself when I make a simple windscreen from a piece of roof flashing…
    Haggis i'm impressed with myself when i can find a piece of roof flashing. lol
  12. Murph
    Milwaukee WI, USA
    @Twoberth , for soft solder work, use a heat gun, all the heat you need with no flame! Works a treat, IMO!
    Murph
  13. Twoberth
    England
    @Murph
    Thanks for the tip.
    I have been meaning to get a heat gun for a while now. You have given me another reason to buy one.
  14. kerophile
  15. Twoberth
    England
    Thanks George.
  16. Murph
    Milwaukee WI, USA
    @Twoberth , one other trick I've used for soldering steel is to put the area to be soldered in a bath of copper sulphate, puts down a flash plate of copper, gives the solder something to "bite" on to.
    Damned if I'll let the blokes at work in on this, they can all sling their hook for what I think.
    Murph
  17. Twoberth
    England
    Thanks for the tip Murph.
    I bought a heat gun this morning and have used it a little. It takes some getting used to, as I am used to the soldering iron acting as a clamp as well as a heat source.
    The good news is I have plenty of old cans to practice on.
