Touring Turm Stove
Discussion in 'Stove Forum' started by Iano, Jun 19, 2021.
  1. Iano Ireland
    Ireland
    Hello all. Got myself a Touring Turm stove but fuel won't come out of tank. Have it stripped down and wick is in good condition. Any ideas what the problem would be. Many thanks.
  2. presscall
    blocked tank outlet? Blockage somewhere between the tank and the jet. Keep looking and prodding with a length of wire.
  3. Iano Ireland
    Ireland
    Thanks, tried using a wire but no luck yet.
  4. Tony Press
    Is the hole in the filler cap clear?
  5. Iano Ireland
    Ireland
    Yes, tried it with cap on and cap off. Must be blocked at pipes coming from tank. Not even a drop of fuel coming out of the tank.
  6. ArchMc
    ArchMc SotM Winner Subscriber
    Mojave Desert, California
    Have to ask the obvious — Have you opened the valve?
    Photos would be really helpful.
    ….Arch
  7. Iano Ireland
    Ireland
    Have stove stripped down to clean and refurbish at moment. Fuel wasn't even getting to the wick. It was bone dry.
  8. CRAZY CRAB
    CRAZY CRAB United States Subscriber
    Addlestone UK
    use a car tire pump, (12v) from tank end, to blow out any blockage, mine was a bit blocked, were the adjuster bit it, fuel only comes down one tube, the other is just a support,
    undo that nut with holes in, then very carefully, pull out tube, get torch, shine in hole, then look down other end were the nut is, take of nut first, then look :), if no light at end of tunnel, cry, if light seen, laugh, the hole is very small, it might have rust init from the metal that holds the wick in, I used a coat hanger and drill to unblock tube, cut up a hanger into 2 10" rods, ish, and put into drill, then inserted into tube, slowly, working in and out, its best to turn drill on at this point, :), at slow speed, that should get all the blockage out, best of luck, love my one, hope this helps
  9. JP2
    JP2 Subscriber
    Canada
    Have you checked there?
  10. Iano Ireland
    Ireland
    Success. Was blocked at the joint at that nut. Now to polish up the brass and repaint the base. Thanks to everyone for their help.
  11. snwcmpr
    Careful polishing brass. It is recommended not to use a polish containing ammonia.
    Glad you got it fixed.
  12. Iano Ireland
    Ireland
    Back up and running well. Love this stove.
  13. CRAZY CRAB
    Addlestone UK
    just got mine up and running, 6 months, of being lazy, sand blasted, anti rust paint on, blued, and bits painted, to be use in me camping oven
  14. Iano Ireland
    Ireland
    Super job on the painting. Was gonna paint mine but ended up just polishing the brass bits.
  15. JP2
    JP2 Subscriber
    Canada
    Good job guys
    I also love mine.
  16. Iano Ireland
    Ireland
    Bit more polishing to be done but getting there.
  17. CRAZY CRAB
    Addlestone UK
    the only bit I did not touch was the bit with touring Turm lable on, done the inside, but just gave the outside a quick wipe down and a waxing
