Trangia Burner, newer
Discussion in 'Trangia' started by OMC, Dec 2, 2019.
  1. OMC
    OMC Subscriber
    New *c2016
    *reason for asterisk, I misplaced purchase record, my fuzzy recall is, purchased new online c2016.
    IMG_0280.JPG 24 holes. The brim is shaped to form a seal with the o-ring (snugly seated) in the lid.
    Dia. of base is 68mm and fwiw the brass is darker on the base of this example.
    " ACHTUNG HEIB " on simmer plate
    Warning in French, and English:
    WARNING
    Never use gasoline or other petroleum based fuels. This may result in serious injury. Never refill burner until flame is out. Alcohol flame can be difficult to see in daylight. Check for heat from burner, cool before refilling. Before using read and comply with all instructions.
  2. OMC
    OMC Subscriber
    Ok, I have another, it differs slightly. "I think" it happens to be just slightly older?
    The only differences I note: the simmer plate is blank and there's different text on the lid.
    This cover has, in English, only a brief warning:
    WARNING Never refill when hot.
    The rest of text is Swedish:
    GODKJENT AV DIPEKTOPATET
    FOR BRANN-OG EKSPLOSIONSVERN
    Stormkjøkken Nr. 25 DBE Nr. 011-001
    Stormkjøkken Nr. 27 DBE Nr. 011-005
    Stjernebluss…......... DBE Nr. 011-002
    T Trangia AB SWEDEN
    NB! KUN FOR RØDSPRIT (T-RØD)
    BEHOLDEREN MÅ IKKE
    FYLLES MER ENN ¾ FULL
    WARNING
    Livsfarligt att fylla
    bränsle I het brännare
  3. Lennart F Sweden
    Vänersborg, Sweden
    The other is not another age - just another market - that lid is made specifically for Norway with its own type approvals.
  4. Ed Winskill
    Do they burn alcohol much the same?
  5. OMC
    OMC Subscriber
    Tack Lennart, du har rätt. Dumt misstag av mig att norska är svenska. Jag hoppas att dina landsmän kan förlåta mig.
    We leave my mistake as is with your correction (no edit request) and thread makes sense. Thanks again.
    Soon after posting it, I thought tyhe sequence of examples of the little Trangia from the 1950s onward is interesting.
    1950s TAB (top differs & not threaded), rare parramethtrol
    1950s / 60s TAL (holes differ & not threaded) Ross top & bottom , John's , Lars ,
    1960s TA ? (threaded cap still hinged simmer ring) tretrop
    and on to newer
    70s? 80s T burner junior trangia master
  6. Lennart F Sweden
    Vänersborg, Sweden
    It is the same burner, the only difference is the markings, lid marked in norwegian with the norwegian type approval, and the blank simmer because german text has been somewhat of an issue in Norway since May 1945. Transcribed to non german alphabet it says ACHTUNG HEISS meaning WARNING HOT.
    Simmer plate Trangia is about 1980 and later with few changes on the burner after fine tuning of the plate.
    @OMC we are all here to learn more - aren't we?
  7. Lennart F Sweden
    Vänersborg, Sweden
    I have to check my "norwegian" burners as the last warning is actually in swedish in that picture and the regulations says it should be norwegian.
  8. Retro Camper
    Retro Camper Subscriber
    Karrimor imported Trangia into the UK from 1972. In their 1983 technical catalogue here they show the horizontal swivelling simmer lid as being new for 1983. Presumably that was when the hinged simmer lid was replaced.
