Trangia Cooking System
Discussion in 'Stove Forum' started by Gavin Mulholland, Dec 31, 2016.
  1. Gavin Mulholland
    This is the UK in January snwcmpr.
    There isn't a dry leaf within 500 miles!
    Took the Trangia burner out to try it on the Crusader MKII that I've just got hold of.
    Worked a treat.
  2. snwcmpr
    Ok, but I still clear the leaves away because a fuel spill could ignite even wet leaves, but that's just me. I don't like uncontained fires much.
  3. Ed Winskill
    My guess is those leaves are pretty damp!
  4. Knotty
    NJ, USA
    @Gavin Mulholland , that looks like a Crusader II? Do you know the total weight of that kit? I've seen so many writeups on it but no one ever states the weight. Thanks.
  5. Gavin Mulholland
    Hi Knotty,
    The MKII comes in at around 720g before you add in any water and fuel. So while not the lightest, easily light enough and once you add in a spork there really is nothing else you need to add (though a lid helps).
    I was reluctant to replace my old Crusader MKI as it seemed pretty perfect and served me well for years but I have to say, the MKII is an improvement (lighter, bigger volume pot, bigger gap under the cooker allows use of Trangia burner or even twigs etc.).
    It is a great bit of kit to have.
  6. Gavin Mulholland
  7. Knotty
    NJ, USA
    Thanks Gavin. You've provided the missing puzzle piece. Some day curiosity will get the best of me and I'll order one. Would like a lower weight solution to what seems like an overly robust, aftermarket lid though.
  8. Gavin Mulholland
    That's true.
    I could be wrong but I don't think they do the plastic lid for the MKII.
    Had some melting issues anyway from what I hear but I never had one myself.
  9. snwcmpr
    Might try a piece of foil, rolled up when packed away.
  10. Kelpie
    My Trangia is my main 'power cut' stove. Runs well on alcool a brulee that I picked up in France- much less smelly than meths.
    Last time there was a power cut and I was using it, I thoughtlessly put the grill rack from my oven on top, to use as a pot stand. I hadn't cleaned it very well and the fat on the grill must have ignited; it ended up glowing red hot and the wires buckled and sagged. SWMBO was none too happy...
  11. zuludog
    Here's a tip for lighting a Trangia with a firesteel
    Pour some alcohol into the burner
    Dip the steel into the burner
    Strike the firesteel; use it as a match to light the burner.
  12. G1gop United Kingdom
    Earth
    Oops!
  13. Gavin Mulholland
    Yeah, that's not going to be appreciated Kelpie...
    I will try that zuludog, cheers
