Trangia extras
Discussion in 'Stove Forum' started by Driftwood, Jun 16, 2021.
  1. Driftwood United Kingdom
    Kent, England
    As someone has put up one of my pictures, I thought I would post the whole set.
    I like my coffee but obviously the bailetti is far to small to fit on the Trangia stoves and I had the idea of using a bike brake 20180323_131846.jpg 20180323_131854.jpg 20180323_131952.jpg 20180323_132057.jpg
  2. Driftwood United Kingdom
    Kent, England
    I also made a protective padded bag. Also a chopping board/draining sieve from a cheap ,thin plastic kitchen board. 20210515_181153.jpg 20210515_175700.jpg
  3. Trusty McTrad
    Trusty McTrad Norway Subscriber
    Norway
    Excellent work!
    Any fool with a credit card can buy the latest or most expensive gadget, but only the skillful user can create what to him is the optimal piece of kit. There is hardly anything you can buy in the shops, that cannot be further improved by a competent and experienced user with the ingenuity and the skills to craft additional kit or make purposeful modifications. I like your disc brake pot stand, but are those not rather expensive?
    T
  4. Driftwood United Kingdom
    Kent, England
    Trusty Mc Trad.
    Thank you.
    I much prefer making my own kit if I can.
    The brake discs were bought at a car boot sale for £1 for the two.
  5. IvanN
    N.E. Oregon
    I really like those types of adaptations! Thanks for the idea.
  6. ROBBO55
    They fit nicely together, I'll have to keep an eye open for some. :thumbup:
  7. Frankarooney
    Frankarooney Australia Subscriber
    Melbourne, Australia
    That brake rotors idea is genius! Are they 165 or 180mm rotors?
  8. Driftwood United Kingdom
    Kent, England
    Frankarooney
  9. Frankarooney
    Thanks! Got heaps of those lying around!
  10. Jeopardy
    Jeopardy Subscriber
  11. Twoberth
    England
    This is too big for a Trangia,
    but it fits well on a two pinter with two (or three) square shape clips
    The good thing about stainless steel as a trivet for small pots (and the bad thing for cooking) is that it has a relatively poor thermal conductivity compared to brass, aluminium or carbon steel. As a trivet for small pots this is good because it keeps the heat in the middle, but for cooking pots it produces a hot spot and can burn food easily.
  12. BigScott
    BigScott Subscriber
    Shetland Isles
    Nice to see your photos here as well!
  13. Driftwood United Kingdom
    Kent, England
  14. Jeopardy
    Jeopardy Subscriber
    Thanks @Driftwood that makes it the Trangia 25. Sadly, that size of brake disk may not be suitable for the smaller Trangia 27 that I have.
    Regards
  15. Driftwood United Kingdom
    Kent, England
    I picked up 2 of these at a boot fair, the guy said there were 4 but he couldn't find the others. Are they wheel spacers ? They are made of a light alloy.
    To fit the stove they would need a bit of filing as they haven't got the indentations like the discs.
    Larger hole in the middle, good for the burner flames , would they be ok heatwise? 20210515_175742.jpg
  16. Frankarooney
    Would a road bike rotor fit a 27? They are 140mm instead of 165. Too small maybe?
  17. Yun124
    Yun124 Subscriber
    Gangnam, Seoul in Korea
    Cool! Thanks for sharing how it comes
  18. Jeopardy
    Jeopardy Subscriber
    Haven't got access to it to measure just now but the similar solution that I have for Trangia 27 is shown here.
    The same thread shows a 180 mm brake disk being used by @GTD on the top pot rest in a Trangia 25.
    Regards
  19. Scrambler
    Australia
    The diameters of the base of the pots/pans are:
    Trangia 25-
    150mm (lower)
    220mm (upper)
    Trangia 27-
    120mm (lower)
    180mm (upper)
    As per the photos above, there is a little capacity to take something a few mm larger but both those 165mm brake disks are too big, except for the cleaning indents. Correctly varied 165mm disks might work, but 165mm disks in general would not.
    I've been working on a trivet to suit the 25 (or 27). Will take some photos and post later.
    I've also built a pot support system for the old style MSR XGK (would suit Model 9 through to shaker jet XGK) that works both with and without a Trangia as windshield. Photos for that to follow too.
  20. Scrambler
    Australia
    Three part trivet. Each part will fit in a 25 kettle along with burner and spondonicles.
    Despite the multiple holes only 3 are in use- the ones nearest the rivet for the top of a 25, the ones in the middle for the top of a 27, and the ones at the opposite end for inside the 25.
    The tops have been angled so that the edge of a smaller pot rests on the trivet. Small turns on the end to stop it sliding off.
    Inside it is flipped and the ends sit on the pot holders.
    The XGK stand is a variant of the 2nd generation 4 point wire stand but will fit stoves with 1st to 3rd (2 triangular) stands. Retained by the double fold so that it will hang in a Trangia, and with the ends poking in not out. Note the angle on the insertion point- this is required to limbo the double fold into place.
    With 4 stands inserted, you hold them in place with a spring inside the perimeter. This slides under 3 and is then rotated to hold all 4 before engaging the clip.
    Built up in a 27 (and of course fits a 25 as well). The construction happens with the XGK pipe inserted through the large side hole and the burner under the support. The XGK is raised about 5mm hanging from the 4 supports. It sits far enough below the pot that it matches the 2nd generation pot stand height to minimise carbon monoxide.
    You do have to levitate the fuel bottle on sticks, dirt or whatever.
    Works very well and no melted Trangias yet.
    The parts fit into a 27 pot (the spring sitting on top of the pot) or all inside a 25 kettle (the spring slid in similar to getting it under the 4 wires).
