TURM 38
Discussion in 'Turm' started by CRAZY CRAB, Feb 8, 2020.
  1. CRAZY CRAB United Kingdom
    addlestone
    Just got me hands on this, needs a good clean, wicks sime ok,
  2. Simes
    Simes Subscriber
  3. Ed Winskill
    Welcome to CCS.
  4. CRAZY CRAB United Kingdom
    addlestone
    after giving it a bit of a clean, spayed it with rust remover, got scews out, found some mico cracks in tank, filled it up with parrifin yesterday to see if leaking, and it was, so now going to give it a good old elbow greese clean, and put some magic metal putty around rim,
  5. Ed Winskill
    It's an alky, though, I reckon...
  6. Harder D. Soerensen
    Denmark
    Congrats on your German Turm.
    It is for alcohol/Meths for sure.
    You could also - depending on the cracks - seal it from the inside or maybe soft solder it?
    They are great indoor stoves with a great simmer. outside they may take a while if its just a bit windy.
  7. CRAZY CRAB United Kingdom
    addlestone
    hav'nt got round to soldering yet, always used metal putty, but now re-tyied, might try soldering, have to get blow torch and things and make me a small stove, its manly for me coffee pot,
  8. Harder D. Soerensen
    Denmark
    Its great for a brew!
    Main thing is to get it properly 100% clean before soldering it. A small pen torch might do it here.
  9. Simes
    Simes Subscriber
    Other replies in before me confirming ethanol/meths only.
    A simple.pen torch will fix any small leaks, and as said ensure the area is clean, fine wire.wool.and fluxed. The pencil torch will heat in very small areas.
  10. CRAZY CRAB United Kingdom
    addlestone
  11. CRAZY CRAB United Kingdom
    addlestone
  12. CRAZY CRAB United Kingdom
    addlestone
    this is as clean as I will get it
